r37ribution
- October 7, 2004
- Ypsi/MI Y town! whoot whooot!!!
- 1996 "Sport" XLT 4.0L OHV
Instead of comming up with a way to monitor throttle position for the volume of gas being added to the intake, would monitoring the volume of air be a better idea? It could work in much the same way as the MAF.
Or even use the mas air readings and/or throttle position to adjust a valve on a small brown gas reservoir. With a reservoir, you could also monitor the pressure and increase/decrease current based on brown gas fuel level and the engines volume of ambient air consumption/throttle position. If the reservoir runs out revert back to the stock fuel/air ratio so as not to burn up the engine.
You could also have a turbo timer and extra dedicated batteries which run for a period of time after you leave the vehicle so as to recharge your reservoir for the next drive. Thus making the volume of brown gas greater and having a better impact on gas milage, tuned correctly of course.
Add a high amp alternator to the mix with a PWM and your all set for tons of HHO fuel.
