my thoughts on what's happening inside the engine....
Hi all
I put in two water4gas style electrolyzers in my 02 xlt. I went from 19 to 25 mpg. No other tweaks as of yet, but some will be needed.
Anyway....
Adding the HHO seems to me to have the effect of raising the octane of the fuel air mixture. This allows the gas inside the cylinder to be compressed more and get closer to TDC before firing allowing more of the energy to be used when the piston is on it's way back down, the way it is supposed to instead of firing before TDC and pushing against the piston and causing the pinging. From what I understand some engines monitor the pinging and adjust fuel mixture to compensate. So, it seems to me we are not mainly gaining power by burning the hydrogen, we are just making the gas combustion process more efficient and therefore taking less fuel to achieve the same amount of power.
The comments on the Hydrogen and Oxygen recombining into water getting power from steam. I agree that is an impractical assumption because of being mixed with the other gases in the intake manifold. I did though fill a gatorade bottle with the browns gas from my electrolyzer. I did it by filling a bucket with water and letting the gas displace the water in the upside down gatorade bottle. Then I laid it on it's side and lit it. Just make sure you don't have anything valuable in front of the bottle when you do it, like say an 02 XLT grill.... ouch. A lot of power in there. I noticed there was water on the table where it was after it shot off. I did it again and made sure the bottle was dry and there was no water inside. It left water again. So, I would surmise that some does get re turned into water, some energy was lost to light and some to heat and some to sound.
Random thoughts and observations....
My next tweek will be to put a pot in line on my maf sensor. It's like what Al did. Then I'll have to do something with my O2 sensors and finally an additive to the gas its self.
I don't think the guys who want to tweek the computer to give them the right stoich are going to be too successful because we can't accurately regulate the amount of the browns gas going into each particular cylinder. I've noticed production rate of the browns gas is not constant it seems to vary with water temp, concentration of dissolved solids in the water, (the electrolyte) and the degradation of the cathode and the anode. The only way to regulate it would be to compress it and store it and regulate it's release. This would put a bomb in your car. The other thing is everyones gas is a different blend. The 14.7:1 is what you want with test fuel, real gas, just the n-Heptane and iso-octane and when all the other things like MTBE and ethanols are added it lowers the stoich.
All it seems that the O2 sensors do is monitor how much pollution is coming out the pipes, if the exhaust is too cool/too lean then it's not polluting enough so it adds fuel, if too hot then it leans it.
If you want to read an interesting piece on browns gas and its unique properties read this. it starts out as a real dry read, but it was worth it.
http://www.eskimo.com/~billb/freenrg/hydroxy.html
I do have a question. Right now I am powering my unit by hooking it right to the + on the battery. I did make an inline fuse. Opening my hood so many times a day is not very practical. How do I find a wire in my engine compartment that is only hot when in the run/acc mode? As you can tell I'm not a mechanic I'm working with a Haynes book and it is no help with this.
I in no way am saying what I've said is gospel, just my observations from tons of reading and a little bit of my own experimentation. I would like to get over 30 and think I can do it with a couple of other tweeks. If you want to know how they work, I'll gladly share. Sorry for rambling so long...
Bill
