How many miles? | Page 3 | Ford Explorer Forums
How many miles?
'01 Sport 4x4 ~107,000 miles.
Old engine rebuilt 2x. Needed timing chains/tensioners again, but replaced whole engine this time since it was burning oil too. New engine has ~4000 miles, 12 of those miles in my truck. No more rattles or squeals. Just put the hood back on the truck last night, so I can start driving it again.
Trans was rebuilt 3x under warranty and now 2x by me. Got tired of just fixing the symptoms and having the problems come back 10k miles later. Just gutted the trans this time and replaced everything while the engine was out. "New" trans has 12 miles so far.
Also this year:
both front hubs,
Torsen rear diff,
new rear axle shafts & bearings,
Brake rotors and pads (all)
new alt, tensioner, idler, and belt too.
Should be awhile before it needs anything else. I'm guessing ball joints or front axle shafts are next.
Edit:Tenikiwon's post reminded me....Mine hasn't had stock size tires since 30k miles, so actual mileage should be higher. Had 32s then 33s with stock gears.
'97 XLT Tranny went at 180k on the ODO, estimated 200k with the adjustment for tire size.
Ran 33s with stock 3.73s since 96k. Ran Amsoil with a K&N oil filter for most of the miles.
97 eddie bauyer 5.0 201,000+ miles original motor and tranny only new motor component was a altenater which was the only time in her life that the check engine light came on.
98 OHV 4x4 bought Nov 2007 with 123k, (EDIT) now has 140k. Paid $3000.
What I've repaired/replaced since I bought it (I'm the 3rd Owner)...
~ Tires
~ Shocks
~ Front end Rebuild Kit
~ Auto hubs
~ Radiator flush, tstat, heater control valve, Rad cap
~ Synthetic Fluids - motor, trans, diffs, ps
~ IAC, EGR Solenoid, EGR Vacuum Hoses
~ Battery
~ Serp Belt, Fuel filter, Air Filter, Gas Cap
~ Spark Plugs & Wires
~ CD/MP3 Player (broken tape deck)
~ Center Console Arm Rest/Lid
~ Front Floor Mats (OEM replacements)
~ Driver's Side Door Lock (broken spring)
~ Throttle Cable Mod (weak spring)
~ Headlight Bulbs
'97 Ex Sport 4x4
88,500 miles
2nd owner
99 V6 OHV XLS 4X4. 123,000 miles. Original owner.
Most popular vehicle in the family fleet. Preferred by my wife over her SRX and by my son over his Eldorado (unless he is going on a date). It doesn't have the performance or creature comforts of the Cadillacs (e.g. heated seats, Bose stereo, plush ride); but, it is easier to drive (e.g. great visibility, simple controls) and has easy access to open storage space. I hope the X lasts for another 10 years.
2000 Exp XLT 5.0 AWD ----> 158K original motor and trans and drive train aside from listed parts
Work done
sway arm bolt: broke the original and the second failed
shocks (all 4)
lower ball joints and bushings
upper control arms (moog) with moog cambers
Belt tensioner
all idler pulleys
power steering pump
A/C comp (rebuilt burnt out bearing)
Front pass CV shaft
Rear drive shaft U joints
Front and rear sway arm bushings
Radiator
Rotors (all 4)
Front pass caliper
Break pads all around
Prop shaft (front drive shaft) : Torn through a few due to bad suspension.
EGR sensor
General mait
All above work done by myself (so much for so called friends) occassionally i even get stumped but not anymore thanks to this great site!
To do list
Rear leaf and shackles
This should be turned into a poll - ie. 1-100k, 101k-150k, 151k-200k, 201k-251k, etc
225,000+
1991 - all original
minus
set of new heads
fuel pump
ball joints
u-joints
exhaust
reg maintenance items
98 XLT AWD 5.0. Just hit 64,000. Other than general maint. nothing has been done to it. A/C needs fixed and it could use some tires.
2000 105,000 miles I have not had to replace anything or do any work to it. I did replace the headers with some TMH but that was by choice :)
mines got 265000 on the original engine, and transmission
1994 4x4 xlt stock
index.cfm
1991 Explorer Xlt (i think)
188xxx or 288xxx not too sure. traded a bagged mazda for it and didn't get much info on it with the trade.
since i have replaced
- tires
- shift motor
- shift linkage
- muffler
- hatch
- misc add ons and replacements
1998 5.0 XLT shes running strong with 190,000 miles orignal tranny/motor.
1998 5.0 AWD Eddie Bauer
-84k on dash -low miles :D !
Bought a year and a half ago not sure what was done to it before but..
-Replaced air ride with regular shocks due to leak
-Idler pully bearing
-Front drivers side wheel bearing
- 2 O2 sensors so i could pass inspection
- Windshield wiper transmission (rusted out and fell apart in a snow storm on highway!)
- Replaced dash lights
-I have the dreaded blend door problem, but i deal with just heat in the winter and open windows in the summer. not bad.
Alot of little annoying problems like the drivers door lock is starting to stick and this door wont open, window lock has a loose connection or something so my passengers can sometimes use the windows (doesnt effect me though lol). But easy fixes once the weather warms up.
Plan on changing the plugs and wires, and tranny fluid soon.
the 302 V8 runs and sounds like a beast. Love the deep throaty sound of my v8! fav part about the truck lol.
96 xlt 4.0 201000 only usual maintence.
92' Eddie Bauer
239k,
trans replaced at about 100k, (previous owner replaced it)
im thinking it was a used one or something who knows, it wasnt shifting today for me, i had to put the lever to 1, to 2, then D, then to the normal OD for it to shift, then when i went back home, it was fine.
New alt at 130k,
Needs-
-Paint
-Rockers
-Right fender (ice, WOOPS lol)
-Headlights (doesnt NEED, but theyre kinda foggy, im getting all clears)
-Exhaust
-Air Filter (last replaced at 130k its nasty)
(delete this post, acc. doubled it) sorry!
96 xlt 4.0 201000 original motor and tranny. only routine maintence
1997 XLT control trac AWD/4WD SOHC 98,000 miles. Low Miles!!!
Repairs needed that I know of...
New exhaust
New tires
New brake pads
Other than that, running perfectly fine! Picked it up 4 months ago for just $3,500.
