- November 11, 2005
- Brooklyn, NY
- 88 89 93 95 96 Aerostars
Some of the relay pliers in that link come with a fuse pliers.
Finally was able to yank it out. I Replaced with a new one and topped off oil. Still won't start. Wonder if there's a problem with the new fuel pump mechanics recently replaced.Some of the relay pliers in that link come with a fuse pliers.
Neato! How do I do that?You could bypass the relay with a wire or a paper clip to test the fuel pump.
So the Check Engine SHOULD light up when I crank? The Check Oil does. What is "cel" and "PCM" power?No check engine light with key on is the problem. No cel, no pcm power. Double check the connectors and fuses.
No cel while Cranking engine is crank sensor, or it's wiring.
So when I turn it on without cranking the only lights that light up are the battery logo and the REAR ANTILOCK lights. If I crank the CHECK OIL light lights up.Cel= check engine light. No cel with key on, = no power on self check , or power to pcm.
Pcm must power on before anything else will.
The cel should flash while Cranking which shows the crank sensor is triggering the ignition.
The crank sensor and wiring is easily disturbed or damaged with extensive repairs
Edit. For clarity. Turn key to on position. Do not turn further to crank. Do all dash lights and check engine light turn on?
Thanks - this is all about testing relays and wiring relays for aftermarket add-ons. Can you tell me how exactly to bypass the relay? Am I using the paperclip or wire on the connector that goes into the relay? Completing a circuit there so the pump turns on? Or doesn't? Thanks!
Ok makes sense. I managed to pull the other two relays. Which is the ecm? Brown or black?Pcm, sorry ecm. Engine control module. Computer.
With no check engine light there is no ecm power. That's the problem. Check the ecm relay.
Fuel pump will not turn on, until the ecm does. Don't know how to explain this any better.
Ok cool so I'd jump 3 and 4 for that test?The contacts on the relay are terminals 3 & 4 which make contact when the coil energizes.
ECM relay fixed it. Thanks for your help!!Pcm, sorry ecm. Engine control module. Computer.
