- March 4, 2007
- anaheim hills,california
- 95 ranger 4x4/ 91 X 4x4
If you have handle controlled interior lights and they are always staying on and you have the door ajar light on, you are going to love this fix.. It's an easy and a cheap fix, and is the way to perform your maintenance of this switch...
Put your fuse and bulbs back in, roll your windows up and get a can of wd40 with the straw...start with your drivers door...from the outside pull the handle up and where the handle goes thru the door, squirt a little wd40 in both those slits...open the door and just work the outside handle a few times...go to the passenger door and do the same....thats all there is to it...good luck...
Update
...If you have an X, You may also need to wd40 your rear hatch latches and If this does not fix your problem and this is a normal fix, you may have some other issues so please read post #8,#12, and 13 of this thread...
...Maybe a broken wire could also be your problem??
http://www.explorerforum.com/forums/showthread.php?t=223988
Update
