I took pictures of the kit I made that would atleast give you guys an idea about how to hang and wire your led assemblies. The only ones I didn't take pics of were the side ones. These are hung by zip ties through the holes in the body along the pinchweld. Easy as that!
Here's the good stuff....
This is where I hung the front assembly. It is hung by...suprise, zip ties...!
This is the same assembly, just showing the wiring. The ground is going to the bolt that's dedicated to the front air dam/deflector. The other is my power lead coming from the cab (junction box after switch)
Just a shot showing you that there are three wires on the driver's side; constant 12v hot from the battery TO the cab (junction box/switch), a hot FROM the switch, a ground for the d/s assembly. I could've ran the same ground to each assembly but I'm tight on cash for school so I saved some wire...
This is the back assembly, hung by zip ties again....
This is a pic showing the wiring to the back assembly. The ground runs to a bolt dedicated to the stock exhaust hanger (which I'm not using) through the frame, The power I tied off of the p/s assembly nearest the rear wheel
This is a pic of where I tied into the pass side assembly...and my pretty redneck exhaust (made out of stock tailpipe minus the tip)
Pass side showing power from switch/junction box TO assembly and ground
I also installed the under rear seat led assembly I made today, instead of using 6 led's like Mustand, I used a modest 13! lol.....I'll show pics of it lit up at night
I also and working on wheel well leds, and maybe an in cowl led too!
