Cobraguy
- February 22, 2008
- Phoenix...Greatest City on Earth
- 1995 EB & 1999 EB 5.0
I am rebuilding one of my Explorers. In the process, I've swapped to a 4406 behind the 4R70W. But I want to also disconnect the front axle if possible. So someone here mentioned the 98 to 01 Ranger using vacuum hubs. Then, they make an aftermarket manual hub to replace the finnicky vacuum hubs. So I started my research. This is the first encouraging thing I found:
http://www.ranger-forums.com/forum2/showthread.php?t=57107&highlight=vacuum+hubs
Looks like someone thinks it's possible without a lot of work! So then I found this...which gives you a good idea of what parts you're looking at:
http://www.therangerstation.com/Magazine/spring07/98_00_Ranger_hub_bearing.htm
Then you can install these:
http://www.tellico4x4.com/product_info.php/products_id/26509
I need to do some price checking. I also need to confirm what the original poster meant my you needing to change the "CV". Does he mean the entire axle? Or just the outer half? Or something else entirely? Once I have that cleared up, I might proceed with this. It's not going to be cheap, but if you really want a true unlockable 4X4, then this is the answer. This is what I've always had in my 4X4's. During the winter months, I just left the hubs locked so all I had to do is flip the lever into 4WD when I had ice and snow. (this is when I lived in Idaho) During the rest of the year, I turned them out and essentially had 2WD. Much nicer.
410Fortune...I'll bet you would be interested in this since you originally were interested in a '95 axle disconnect. This would be even better other than you wouldn't be able to engage the axle with the flip of a switch.
