vintage2
- January 21, 2022
- washington, DC
- 13 PIU
Hello,
I'm looking to flash the HVAC firmware (calibration, strategy, ecu *.vbf) files in my 2013 PIU in order to enable automatic climate control. I'm updating to SYNC 2/3 and the 4" sync bezel / HVAC don't work, basically forcing fail mode full-blast. I'll also be wiring up climate controlled seats (with the TEDs, not the heated pads). I'm hoping to avoid purchasing a different module as the hardware looks pretty much the same, leaving software / firmware probably being the major difference.
Anyway, does anyone with automatic HVAC heated + cooled seats happen to know the correct numbers of the calibration, strategy, ecu *.vbf files used on a 2011-2015? I've randomly googled, downloaded and flashed the numbers (via forscan firmware flashing) of some Taurus Sho firmware files but obviously those lack the rear climate control.
This is the stock MANUAL firmware listing:
Part Number: DB5T-19980-AF
Calibration Level: DB5T-19980-AF
Hardware Number: DB5T-14F213-AA
Secondary Boot Loader: CB5T-14C181-AA
Strategy: DB5T-14C178-EA
Calibration: DB5T-14C179-EB
ECU Configuration: CB5T-14C673-AA
AUTO firmware listing:
Thanks!
Thanks!
