Updated 01/10/18
I want to put together a master list of all the Forscan Settings that apply to the 2011-2015 Police Utility Model years in one thread. I know we can use the search box but thought this would be easier. As this thread continues I will edit this first thread with any changes and updates that we find. The information used to compile this list comes from the site
FORScan 2011-2018 Explorers thanks to Livinitup. I have also added an explanation of the functions.
APIM * Accessory Protocol Interface Module* 7D0
FCIM * Front Controls Interface Module *75A
ABS * Antilock Brake System* 76D
RCM * Restraint Control Module * 737
PSCM * Power Steering Control Modulal*730
ACM * Audio Control Modulal *727
BdyCM *Body Control Module *726
SCCM * Steering Column Control Modular *724
IPC * Instrument Panel Control Module *720
HVAC * Heating Ventilattion Air Conitioning* 733
GPSM *Global Positioning Module *701
2011-2015 Police Utility Settings / Module Address Settings / Notes
1.
Police Rear Door Configuration - This setting causes the rear doors to ???????
BCM 726-08-01 xx*x zz 0=Disabled, 1=Enabled
2.
Dark Mode - This setting allows the doors to open without turning on the interior lights.
BCM 726-08-01 xxx* zz 0=Disabled, 1=Enabled
3.
Police Liftgate Unlock - This setting causes ?????
BCM 726-08-01 *xxx zz 0=Disabled, 1=Enabled, functionality untested
4.
Police Rear Door - This setting causes ?????
BCM 726-08-01 xx*x zz 0=Disabled, 1=Enabled, functionality untested
5.
Courtesy Lamp Dimming - This setting causes the interior lights to fade off.
BCM 726-08-01 x*xx zz 1=Immediate, 2=Theater Dimming
6.
Unlock Feedback - This setting causes ?????
BCM 726-17-01 x*xx zz 0=Disabled, 1=Enabled
7.
Enable Keyless Entry - This setting for using the key fob.
BCM 726-18-01 100 5 zz
7(A).
IPC 720-01-03 808A 000B5 or 00035
8.
Locking Light Feedback - This setting causes ?????
BCM 726-15-01 xxx* zz 0=Disabled (PIU Default), 1=Enabled (Explorer Default)
9.
Remote Start Enable Configuration This setting causes the use with remote key fob.
BCM 726-19-01 **** zz 0148=Enabled, 0047=Disabled
10.
Instrument Panel Cluster Options - This setting causes ?????
IPC 720-01-03 **** C8 F3=Enabled, F823=Enabled w/climate seats, FC27=Enabled w/climate seats & Heated Steering Wheel
11.
Liftgate Smart Unlock - This setting causes ?????
BCM 726-16-01 xxx* zz 0=Disabled (Default PIU), 1=Enabled (Default Explorer)
12.
Perimeter Car Alarm (Disabled on PIUs) - This setting causes ?????
BCM 726-20-01 xxxx x*xx zz 0=Disabled (Default PIU), 1=Enabled (Default Explorer)
13.
Enable Aux Without Sync & Sirius This setting enables the Aux input to be used.
FCDIM 7A5-01-01 2021 1000 00zz Sirius also requires an ACM w/Sirius radio and a Sirius antenna
14.
AWD Gauge & Average Speed/RPM - This setting causes ?????
IPC 720-01-02 *xxx xxxx xxzz 8=Disabled, B=Enabled
15.
Compass Display This setting causes the compass display next to the dash odometer.
IPC 720-01-02 xxxx xx*x xxzz 0=Disabled, 6/F=Enabled
2011-2015 Model Year Common Settings
1.
Keyfob Car Finder Setting - This setting causes the horn to hook when unlock key fob 2X.
BCM 726-15-01 xxxx x*xx zz 0=Disabled, 1=Enabled (Default)
2.
Concurrent High Beam/Fogs - This setting causes the high beams and fogs to light together.
BCM 726-11-01 xxx* xxxx xxzz 1=Disabled (Default), 2=Enabled .
3.
Golbal Open/Close (Needs additional wiring) - This setting causes both front windows to lower or raise from remote key fob.
BCM 726-04-01 xxxx x*x* 0=Disabled, 1=Remote, r
4.
Tire Size - This setting causes the calibrate the speedometer for different tire sizes.
BCM 726-45-01 xxxx **** xxzz
5.
Number of Turn Signal Flashes - This setting changes the number of monetary flashes.
SCCM 724-01-01 xxxx x*xx zz 0-3=1 Flash, 4-5=2 Flashes, 6-7=3 Flashes, 8,9=4 Flashes, A,B=5 Flashes, C,D=6 Flashes, E,F=7 Flashes Airborne_Ape's Find
