- January 22, 2007
- selkirk, manitoba
- 98 supercharged 347 sport
i have posted this in a ranger message board, figured i would also put it up here.
i have a 07 level 2 (has 33's on it if this will count) with around 260kms (161 miles) on it. starting this winter, i have noticed a cluck or thud when the truck is in 4x4. it feels like its from the front end, or front side of the truck, and not the back. the other problem is its intermittent. it will happen when being driven a distance of around one km, or around a 1/2 mile no matter what speed. also the faster you are travelling, the harder the clunk or thud. the best way i can describe it is it feels like hitting a joining point on the road that is separated. it will only do it in 4x4 and not 2wd. the front u joint was replace around 2 years ago, as well as the passengers front cv axle. the drives axle was also replaced in the spring if i remember right, or last year. there is no grind sound, and its not popping out of 4x4 either.
thanks in advance.
thanks in advance.
