bmcneely0
- December 24, 2022
- Clover, SC
- 2017 Ford Explorer XLT
I have a 2017 Ford Explorer and for the past year or so I’ve had a problem with the left front turn signal. When I use the right turn signal I have no problems. However, it seems that in very warm (< 20 degrees F or >95 degrees F) when I use the left turn signal, the rear turn signal indicator works but the front turn signal does not and inside the vehicle the left turn signal indicator flashes fast indicating a problem. I’ve had my mechanic look at it and at first they said said it was a connection problem and put something on the connection to make it better. This worked for a while and then stopped. Next they replaced some kind of pigtail connector. This worked for a while and now has stopped working. It also seems to consistently happen in very cold or very hot temperatures as noted earlier. I looked at this post which seemed like an option but it was for a 2003. So I didn’t know if it would still apply to a 2017 and also both of theirs were intermittently out and mine is consistantly the left front turn signal. Any ideas on what else it could be? Appreciate any suggestions. Thank you in advance
