lifeguard379
- July 10, 2004
- sacremento,ca
- 93 eddie bauer 2 door
Do you have the measurements for any of your breckets?
Thanks, Tim
Thanks, Tim
JTX said:Josh watch it on anything but mud, i ran mine with 3.73's in the back and 4.56's welded in the front for a day. As soon as i hit hard dirt my carrier cracked in half. That was with a d35, you'll be pushing the limits of the d30 if you do. If i was you i wouldnt even wheel it unless your stock and need 4wd. When the ratios are different somethings gotta give, it will either be the carrier, axle shafts, driveshaft, or worse case your t-case will pop. Just be easy on it, until you get your gears.
bmxking5 said:Not sure about if you'd need to change stuff around for the steering linkage, but if you look at 034x4's install, he showed where he braced the frame and just bolted the steering box to the frame. He used a Toyota steering box, but it's the same idea with the 1st gen Explorer steering box (just three bolts through the frame). Then it's just a normal steering setup, pitman arm, drag link, and tie rod.
