Jefe's 700R4 swap | Page 11 | Ford Explorer Forums
Jefe's 700R4 swap
did you use a regular truck 700r4? I think i read some where that it has to be a the small 700r4 (behind GM’s 2.8L, 3.4L, and 3.8L) is that really the case? i have a full size regular 700r4 and need a tranny in my 4.0 explorer, just wondering if i would be able to use it or not. thanks
Go get a junkyard 5.3 GM motor ($400-500), the Advanced Adapters kit ($180) and put it in your Ex. 295 HP/330 TQ for under a grand.
I'm assuming you mean 4.3 and what would you do about all the electronics. Most states say you need to keep what was on the motor to being with.. Soo, that means all sensors etc and you'll need to get the GM ecu to work on the ford.
I doubt very much that taking a GM motor (efi) and getting it into a Ford (efi) is going to be that easy.
~Mark
I mean a 90 degree 5.3 GM generation III/IV V8. Advance adapter kit will mount the newer V8's to the older 700R4/4L60 tranny's. Summit sells Carbed intake manifolds to mount to the newer GM engines that have controlers that are plug and play for Carbed applications. Other than buying it all, it should be an easy swap. Engine mounts should be the only guess work to be done.
There have been a few LS to Mustang swaps done...what would make an Explorer any different?
If I understood that correctly.. You are going to get an EFI engine, and put on a carb and install it into a vehicle that came with EFI originally?
For areas without emissions I could see that working, but even with Arizona's somewhat liberal conversion/emission rules that would never pass.
From what I've read though, in some areas (I'm "thinking" Kenutcky) there are no emission tests so you could get away with that conversion.
But it is possibly another option, I just doubt it was be as easy as the 700r4 swap on the 4.0 since with the 4.0 there is almost no wiring "changes".
~Mark
No emission here besides in one city, ;)
No emissions in Nebraska and Florida. In Alaska, when you change anything without a C.A.R.B. sticker it's illegal. My KKM intake on my Ex had to be removed every time I went to register it again. Obviously, I would do this conversion with no regard for emmissions. However, the 5.3 probably runs much better than the 4.0. You can get the EFI stuff to work but the cheap way is the carbed setup. (The only reason I'd do this is to get a better tranny and more HP for the dollar. Not to mention the after market suport for these GM engines.) They have controllers that will "plug-and-play" with the GM EFI and will net awesome fuel mileage and power. You just have to pay the extra. I was speaking of the most budget build possible for his 90 degree 700R4.
