Jon And Sheri's Vitamin D Wagon | Page 50 | Ford Explorer Forums
ok i checked the chart on the welder and used it's recommended settings for 1/8" using .035 wire, but I should have switched to .23 .
Oh well, at least I know how to use a grinder safely.
Then I turned up the heat and triple passed the tow hitch and thingys with the holes
Lookin good - especially on the D-ring points!
Wait, is that flux core?
you've got what looks like holes in the welds.. that's porosity, and it's a bad thing.
I've always been taught weld uphill. You get good penetration that way.. Downhill doesn't give you the penetration.. Something about the heat of the metal.
~Mark
that's because the puddle will run into your arc area as your pulling the weld which will greatly effect the penetration. However if you are looking for a better looking non-structural weld it will be better to shoot the puddle up while you pull down. This works well on thinner plate or where you need to fill a vertical gap. Again only on non-structural connections...
Well, at least I know I was doing it the right way (weld Up), even if I didn't know why I was supposed to do it :)
Now Turdle needs to practice welding "up" :)
~Mark
Ok I do believe all the welding is complete. I did triple passes on all the bumper bracket and clevis tab joints on the inside. I got all the license plate and light holes drilled and the upper part has been smoothed. I just need to smooth the bumper now.
Looks like I might have this thing powder coated and installed tomorrow, which will be good. My lovely bride is tired of bumper building about now.
ok, frame brackets and clevis tab welds
receiver
I made a inside lip for a front trim and bracing
the ammo box tray
And man do I love those flap discs.
oops
sorry Tom, I missed the question. I am using c25 with 035 wire. I think it was just a little too hot, and lack of metal prep.
Dunno if you know about this or not, but that could be really bad news while welding. Check out the link
Common Cleaners Can Turn Into Poison Gas
If you did already know, my apologies, and perhaps someone else can learn from my link.
Bumper looks great though, what thickness are your brackets/shackle mounts? I've been meaning to make some myself, and I really like how yours turned out.
Yeah, brake cleaner and heat = no good. I only used it to clean off the cutting oil from drilling the holes
The metal thickness for brackets and tabs is 1/2"
Maybe a safer option: rubbing alcohol (isopropyl). Plus it can be used to clean even the natural oils from your hands. It often comes in different percentages (like 70% or 90%) - get the highest percentage.
That looks great, a lot of time and work went into that.
BTW, since you have the receiver tube going out the back by a few inches, why not add bracing there? I'd make a brace on each side of the receiver shaped like a long triangle, going from the back edge of the receiver. Run the braces upward or downward to the top or bottom of the bumper, the middle isn't ideal for strength. Welded in that would strengthen the bumper for pushing and pulling forces. Just a thought before you finish and paint it.
I agree. Beef it out.
I think its fine - the reciever has been welded on both the front and the back side of the bumper - in order to pull out that reciever, you'd have to first shear off 8-9" of weld in compression, and another 8-9" of weld in tension.
Does that ***** have a top yet? :D
If that is the non-chlorinated stuff, it is not problem. Otherwise no way jose!
Its not... the green can is non- chlorinated and is fine for fab work... red can is instant death. :D
