Drop Out Dana 60
Takes all Dana 60 parts "gears, bearings, setup kit, lockers"
High or Low pinion in the same housing
Symmetrical pattern can be used as a "high pinion, low pinion or flipped high or low"
8620 STEEL housing "not IRON or Aluminum" Very very strong. 2 to 3 times stronger then all other iron housings made.
Roughly 3/4" to 1" more clearance then any Dana 60 housings out now.
The bearing caps will be keyed so there will be no mix up and also making the side adjusters "miss fit" a thing of the past. This will also help eliminate bearing deflection on the carrier bearings.
These were designed, built, poured, machined 100% in the good ol' USA by Good ol' Americans!
Dan at Ruffstuff Specialties will be making all the housings for this new axle. I know I am missing some stuff and will post completed pictures and will start a general testing thread soon. See you all at KOH!!! Thank You Jason Ratcliff JRAT OFFROAD
