leaking coolant | Ford Explorer Forums - Serious Explorations
leaking coolant
wbdechiara
2002 eddiebaurer explorer
I have a 02 eddiebauer explorer 4.6L and found a antifreeze leak and it is leaking above my transmission but cant see the source of the leak does anyone have a starting point for my to look for the leak?
I had a similar issue and located the problem by renting a pressure tester from my local autoparts store. Once pressure is pumped into the system, you should be able to see the anitfreeze leak. I was fortunate that the thermostat housing was causing the leak and antifreeze was draining onto the manifold, and then to the back of the motor. I bought the kit and is was an easy install and fixed the problem
bizzs
