Lift Laws
The_Renegade
Halifax, NS, Canada
1991 XL
Nova Scotia, Canada
No more than 3" Body lift, 3" susp. lift, and I think 38" tires here...
Phil B.
Join the Elite Explorers for $20. Gets rid of the ads!
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
thecause17
Hutchinson, PA
'99 Ranger 4.0 4x4
Critical_Level2 said:
In Pennsylvania the lowest part of the frame must be within 30 inches of the ground.
Tires cannot stick out past the fenders
Fender flares are allowed to be used but have a max width of 3 inches.
I dunno how it is in your area of PA, but here, they're very leniant about the tires past the fenders. I've rarely heard of people getting fined of pulled over for that, and when they do, it's usually for something else, and they get nailed for that just because they were already pulled over...kinda like illegal tint, nobody cares until they pull you over for something else. There's Trucks running around here with 35's sticking 3+ inches past the flares, and they don't get pulled over. :burnout:
explorer_50
Fergus, Ontario
1991 Explorer XLT 2WD
Ontario, Canada
the only law i can think of off hand is that your tires cannot pertrude anymore than 1" past the fender. Flares are allowed but must be under 4"...i think. ill check it out and get back to you.
TheRookie
Traveling SAS guru
West Chester PA
91 explorer xlt
PA
bumper height
5,000 lbs. or less GVWR 24" front 26" rear
5,001 lbs.-7,000 lbs. GVWR 27" front 29" rear
7,001 lbs.-9,000 lbs. GVWR 28" front 30" rear
9,001 lbs.-11,000 lbs. GVWR 30" front 30" rear
from frame or factory bumper
(which ever is higher)
3 inch body lift max.
Frame height
Tires may Not stick out past fenders. This is strict where I am but lax in other areas.
Flares are allowed but no more than 3 inches wide.
Edit : PA is likely to change this law to frame height only.
Rear Block
3" block in rear max
(suv) max rear is 1"
Shackle
2" over factory length shackle max
And headlight
(truck) headlights below 54 inches
(suv) Headlights must be below 48" from top of headlight
Link to most states laws
Note Pa is kinda odd with the differences from SUV to truck. You can register your Explorer as a truck or as a wagon. When registered as a truck my understanding is your ex is goverened by the laws of truck and not those of SUV. If registered as a truck you will have "truck" on your plate.
AUTOTECH SON :)
Albuquerque, New Mexico
92 XLT totaled R.I.P
:bounce: NEW MEXICO
The restrictions this state has are that headlamps can't be higher than 54 inches, and taillamps can't be higher than 72 inches. However, it's no-holds-barred on the type of lift used. :D
Dignan
Idaho Falls, Idaho
'99 5.0
Utah
You would think that Utah would be pretty liberal with their lift laws considering it is home to the Mecca of offroad, Moab. But they're not. They change it every year and nobody really knows the laws. I had to go to five different shops just to find one that knew the current law on body lifts and then they failed me. :banghead: They body lift law is currently a max. 3 inches between frame and body so with the bushings sitting at about 1.25" the biggest you could go is 1.5" there was a time that you could add a 3" body lift, but I guess they changed the wording of the law. Since I failed the inspection I didn't have current registration so I was pulled over by a highway patrolman and his advise was to get a suspension lift so that it wouldn't be so noticeable that it was all body lift. I thought it was a little odd that the solution to my illegal lift would be a bigger lift, but hey I'd better do as the officer says, right? ;)
Xzibit A
Ashburn,VA(NOVA)
02 xlt 4.6
hmmm about the explorer being a passenger vehicle i belevie the 1st gens are still trucks correct, i know my 85 4unner was a truck, but my truck passed VA state after i put covers on the fog lights, they dont have to measure bumper height, they can get yu with the turning radius though.
Mbrooks420
High Voltage.
EF Vendor
1998 Mountaineer AWD
In PA none of the Explorers were never trucks. Bronco's, K5's. Suburbans, are all station wagons.
explrig91
pottsville, pa
1991 xlt
well i guess the cops here in pennsylvania ain't gonna be happy wit my 91xlt wit a full size 44 SAS wit 38x15.5 tsl's
ExploderXLT00
Rockland County
'00 XLT
NJ was always the armpit of america and still sounds like it is :fire:
Noved87
Kelso, Washington
'94 Sport
washington is the best! body 3" max suspension wahtever you want. how about 12" suspension 3" body and 38" tires
i am no longer sure of this. i have now read 2 different things in 2 different places.
Creager
Charlotte, NC
'92 Sport 4x4
HAHA north carolina is so north carolina
NORTH CAROLINA
Don't even think about going higher than 6 inches from the factory height - unless, of course, you get a written OK from the Commissioner of Motor Vehicles. You don't need a permission slip if yours is a multipurpose ride atop a truck chassis that sees some dirt.
HAHA
So i cant lift my truck... but if i put a Chevette body on top its OK!
dreamr
Lynnwood WA
99 XL / 4x4 / 4.0 ohv
Well actually according to the DOL it is based on bumper height, and the tread of the tire must be covered by the mud flap.
<4500 GVWR=24" front 26" rear
4501-7500 GVWR=27" front 29" rear
7501-10000=28" front 30" rear
Meaning I can go up 3 more inches :thumbsup:
toddious
winter park, FL
1996 Limited 4x4
anyone know the laws in florida on lights on your roof? namely, do you need the covers on them? thanks, todd.
XplorerKid
Rolling on 37"s
Winter Haven Fl
1997 Xplorer
Todd, i had 4 Pro Comp 6"s on the roof of my Jeep, and never ran them covered, Never ahd a problem with police sayign anything bout them. Even when i was pulled over he didnt say anythign bout them...
toddious
winter park, FL
1996 Limited 4x4
thanks for the tip.... so xplorerkid, when we meeting up to go offroadin? we're close enough, we definately should. todd.
toddious
winter park, FL
1996 Limited 4x4
that truck is bad!!
XplorerKid
Rolling on 37"s
Winter Haven Fl
1997 Xplorer
As soon as i get my next rig built, in the process of selling my jeep.... Ill let you know when i get my next rig trail worthy....
P State lift laws Shocks, Suspensions, Lift Kits 10
2 Lift Laws Shocks, Suspensions, Lift Kits 0
R Lift Laws? Shocks, Suspensions, Lift Kits 12
E Rough Country 5" Lift Shocks, Suspensions, Lift Kits 8
traveler New long-travel lift kit Shocks, Suspensions, Lift Kits 0
B Body vs suspension lift? Shocks, Suspensions, Lift Kits 5
fiftyfordfloored 1994 Ranger Lift - Experiance With Proposed Setup Shocks, Suspensions, Lift Kits 5
C Unorthodox lift for a 07 explorer Eddie Bauer Shocks, Suspensions, Lift Kits 7
2 Lift kit help Shocks, Suspensions, Lift Kits 2
Rick List of Useful Threads Shock Suspension Lift Kit Forum's Best Threads Shocks, Suspensions, Lift Kits 1
Z lift options for 32 in tires? Shocks, Suspensions, Lift Kits 2
X Body Lift for 99 explorer? Shocks, Suspensions, Lift Kits 1
G I need recommendation about lift my truck with spindles Shocks, Suspensions, Lift Kits 0
G 2000 Mercury Mountaineer 5.0 V8 AWD need lift Shocks, Suspensions, Lift Kits 3
E Want to lift my 2003 explorer Shocks, Suspensions, Lift Kits 1
A Wanting to lift my 2005 explorer Shocks, Suspensions, Lift Kits 1
RangerX Quality breakage on my Rancho lift Shocks, Suspensions, Lift Kits 3
L Axle Drop & RA Drop Brackets for a 2" Lift? Shocks, Suspensions, Lift Kits 0
B max tt lift Shocks, Suspensions, Lift Kits 1
W '08 XLT Lift Options Shocks, Suspensions, Lift Kits 0
madbutcher Common tools for a 1gen lift kit installation? Shocks, Suspensions, Lift Kits 2
M first gen lift Shocks, Suspensions, Lift Kits 4
R lift options, going round and round in my head Shocks, Suspensions, Lift Kits 8
jrme To body lift or not to body lift Shocks, Suspensions, Lift Kits 3
D Rear Lift issues on a 2000 Explorer Sport Shocks, Suspensions, Lift Kits 2
R 99 2wd explorer lift Shocks, Suspensions, Lift Kits 0
F Best lift for a 92 without messing with driveline??? Shocks, Suspensions, Lift Kits 4
F need help with a lift!! Shocks, Suspensions, Lift Kits 3
F 2001 Ford Explorer Sport Lift? Shocks, Suspensions, Lift Kits 3
T 2006 explorer lift kit Shocks, Suspensions, Lift Kits 0
P Couple lift questions! Shocks, Suspensions, Lift Kits 1
D Rancho Quick Lift Shocks, Suspensions, Lift Kits 2
J looking for a 99 ford explorer xlt lift kits Shocks, Suspensions, Lift Kits 0
R 1998 Explorer Lift Shocks, Suspensions, Lift Kits 6
9 Body Lift Help Shocks, Suspensions, Lift Kits 1
9 Fitting 32 inch tires with only 1-2inch suspension lift Shocks, Suspensions, Lift Kits 0
D spring/shock noise after f150 coil spacer lift?? Shocks, Suspensions, Lift Kits 1
N lift kits for 08 explorer xlt Shocks, Suspensions, Lift Kits 1
Explorin'VA 1" Body Lift Questions Shocks, Suspensions, Lift Kits 1
P Rear lift only Shocks, Suspensions, Lift Kits 1
K Price drop on Superlift lift kits! Shocks, Suspensions, Lift Kits 4
S help on 2Wd lift on 93 explorer Shocks, Suspensions, Lift Kits 0
S What shocks to get with TT and Shackle lift. Shocks, Suspensions, Lift Kits 0
T Body lift questions Shocks, Suspensions, Lift Kits 7
M drive shaft issues with lift Shocks, Suspensions, Lift Kits 4
2TimingTom SOA without the lift? Shocks, Suspensions, Lift Kits 15
S lift vs center of gravity fix Shocks, Suspensions, Lift Kits 4
L 87 ranger lift options Shocks, Suspensions, Lift Kits 5
N 4" lift ? Shocks, Suspensions, Lift Kits 12
C Lift Spindles for 4x2 Shocks, Suspensions, Lift Kits 1
Similar threads
