Big6ft6
- January 3, 2007
- Madison, WI
- 1997 5.0 AWD
So,
Bought the new 97 5.0L for $2,200 with 91k mi. Could tell the front end was a mess, so took it in to have the professional take a look before I invested a dime.
Here is what came back
1) Upper and Lower ball joints, upper VERY bad (I knew this)
2) Right outer tie rod end is bad
3) Rear axle seals are leaking
4) Metal flakes on the rear diff drain plug
5) Pinion has looseness and pinion seal is leaking on rear
6) Shake on acceleration...think it is a CV axle
7) Exhuast hangers broken
8) needs tires bad ( I knew this too)
I'm comfortable doing all the work except the rear axle stuff, I've never gotten into axle seals, and definitely don't want to get into a rear differential.
Should I punt or keep the truck?
