Problem solved. The drivers side exhaust needs a hangar point in front of the flex tube. I installed this today, trimmed the bolts and the startup sound is gone. 2 parts from Amazon and I attached it to the ONLY point available. Btw, I decided to double up on the Ford recommended "Stainless clamp around the flex tube" official BS fix. I first tried their way. No dice. The I used 2 of the plumbing couplings (without the rubber liner) on the flex pipes and the problem was still there, so the OFFICIAL Ford fix does....not...work.
Then the hangar. The added hangar was not difficult to install, but you will need to trim the bolts. See pics for parts used and after install. Pathetic that I'm driving around with a plumbing clamp to fix a FORD issue. But....LOVE that motor.......
Sooooo nice to have a quiet motor that does not embarrass everywhere you go! I even heard that thing rattle at speed at times. Ugh.....but gone now.
PS, I removed the remaining flex pipe mesh because it was falling apart. It is quite pointless. Use leather gloves to hold it as you cut it off. Little bits of stainless mesh will go....everywhere.
View attachment 394913 View attachment 394914 View attachment 394915 View attachment 394916 View attachment 394917 View attachment 394918
