jd4242
- October 15, 2008
- va beach
- 92explorer&94 ranger
JD, you need to post how you wired the resistor and capacitor in the circuit.
Also, post the link to where you found the info.
It's rarely as simple as adding a capacitor and resistor in a higher current situation.
I'm guessing you have the capacitor and resistor all in parallel before the relay.
The idea is that when power is applied to the capacitor, it charges and the voltage rises to 13v flipping the relay. Then, when power is removed, the capacitor slowly discharges until voltage drops below the relay keying voltage.
It can get complicated since a relay can actually draw quite a bit of current (relatively speaking).
I basically have 12volts going to my fan sensor switch in my radiator when key turns on,then to a Bosch 75amp relay....i wired the resistor after the fan switch inline to relay..the ""positive "" of the capacitor is joined to the relay wire after the resistor, the negative side goes to ground..pic may help..i used a 10 kilo-ohm resistor and 1000 micro-farad 16v capacitor. .it seems to work when unplugged from relay (fan switch opens and voltage slowly goes to 12v) but once plugged the wire to relay the voltage dropps and doesnt go back up,nor kicks the relay on..fan switch is closed and gets 12v before resistor
