jd4242
- October 15, 2008
- va beach
- 92explorer&94 ranger
Having some good discussions over on rps about E85 or E50 so thought id share some of my thoughts..
Ive been reading up and from what i can see there isnt much gains to running over a E50 mix..octane is not liniar so it does not increase past the point of E50..the only benifit i see once past the E50 mark is the amount of fuel that is injected. .obviously the more fuel,especially ethanol will cool the chamber but is it needed for the down side effects. .if i can reach full timing off E50,which many can,then no its not needed..im running two intercoolers so my IAT shouldnt be crazy and only running 11:1@16Lbs..not crazy in the performance world..
E50 has many benefits over E85 i see..still get the ""105"" octane,cooling effects of ethanol, less chances of gumming/corrosiveness,less strain on pump and biggest better mpg..
Ill have to test the E85 every time if i use pump E85,but im looking more towards getting a barrel of E98 and mixing my own gas..that way i know its a 50/50 mix everytime
My thing is,i try and run around 10-12gallons in my rear tank for traction for my old setup..any more and it didnt seem to help,just added weight. ..i got about 12-14mpg on my last setup doing average driving,way less when playing around...
If i were to run E85 and gas mileage is as bad as some say,33-40% worse..id be getting around 8mpg with average driving and even worse when racing....i would barley get 90miles per tank and EVEN less when racing..that wouldnt even get me to the race spot,hell id have to fill up twice just to go race..this is a true street truck and it will never see a trailer unless broke down..lol
Im not saving money by using all E85 as gas is cheaper than it right now...biggest question is can i peak my timing out using just E50..
