Travis Brown
- February 19, 2020
- Location
- California
- California
- 2006 Ford Explorer XLT
Background
The timing phaser and/or chain went bad in my '06 4.6 with 213k and rather than throw parts at an old engine, I tracked down a '08 Mustang engine with 79k miles from a local wrecking yard for about $1000. The Mustang engine is an aluminum block version of our 3V V8s, so it should save a whopping 80-100 lbs. I figure that weight savings will help to offset all of the off roading gear I'm about to add to this rig and the lower mileage is awesome. The Mustang engine is rated for more horsepower and torque than our engines due to different exhaust, intake, and tuning, but for now I'm just going to swap the long block and keep everything else stock.
Removing the old Engine
I've done engine swaps before, but this one is not for the faint of heart. You have to basically disassemble the whole truck to get the engine out. I was following the factory shop manual, but it failed to mention a few key steps, leading to a lot of head scratching. Here's the process:
* Remove front and rear drive shafts
* Remove frame cross member (the shop manual didn't mention this, but it's absolutely critical)
* Remove transfer case
* Remove exhaust Y-pipe - This was very tricky because the down-stream cat and muffler were in the way. I wound up having to unhook the rubber muffler hangers to get enough clearance
*Remove starter
* Remove transmission - This is pretty tight, but doable if you have about 3ft of wobble extensions
* Remove cooling fan, hoses, and upper intake manifold
* Detach power steering pump, and A/C compressor - The A/C is held to the block with studs, which I wasn't able to remove before pulling the engine. I just hoisted the engine and let the compressor slide off the studs
* Unbolt the motor mounts
* Pull the engine
Engine Accessory Swap
Here's the old engine next to the new one
I haven't really gotten started on this yet, but I've identified quite a few difference between the two engine setups
Any thoughts on what to do with this line?
*Remove starter
* Pull the engine
- Upper intake manifold and throttle body
- Coolant-heated PCV (Explorer only)
- Oil pan shape
- Oil temperature sensor in the oil pan (Explorer only)
- Engine Mounts
- Pump-mounted cooling fan (Explorer only)
- Coolant tubing
