Well I worked 6hrs of OT today, ugh. But I got to work on the mistress...
Here's what I've got:
I grinded off the nut of the leaf center bolt, and it still wouldn't come off! So I chucked a big old C-clamp on the end and presto! The rusted chunk popped right off!
I had been trying to get another center bolt to replace the ones I was grinding off, however, it would seem the auto part stores in my area don't have them anymore... My options were then left up to: Hitting up the junk yard and seeing if I could find a 7/16" diameter that was long enough and rust free; The 3/8" diameter replacement bolt that came with the kit; Or using a standard bolt that had a similar head diameter but was still 3/8".
Well, after much debating, I decided to go with the bolt from the kit because it still fit despite having a bit of slop, I think the odds of finding the actual one in usable shape from the junk yard are very slim, and the hex bolt didn't have as much 'height' to the head for the axle to drop on to.
From there the rest was easy! Add-a-leaf...
...and shackle.
As you can see there is a good amount of lift between the now 'lifted' driver side and stock passenger side. The passenger side did prove to be a little more challenging, mostly due to the shackle that came in the kit. It seemed as though it was a bit more 'puckered' towards the ends and for the life of me I could not get it to clear the frame mount or leaf spring! So... I separated it with a vise and used washers and a shock bushing to keep it spread.
It was kind of like arming a bomb. Lots of tension and no sudden moves! Once it was all lined up and the bolt was placed a quick tap from a hammer and the washers went flying! For the leaf, I went ahead and just hoisted the vise up and separated the shackle. Enough tension that it just held the vise in place so I decided to take a picture of it as well
Eureka! A little more pep is present in the rear!
All that is left is the shock mounts, but of course... my super power kicks in... a sheared bolt:
Some quick hardware, mounting the shocks, and cleaning the lower mounts. Looks like it will be back on all 4's tomorrow! Adamsbro is coming over to give me a hand bleeding the brake lines and aligning it, two fairly important systems that need to be in check if I want to drive this thing! (Thanks again Man!) So close....!
