skillz105
- September 8, 2011
- raleigh, nc
- 94 ford explorer sport
I have a 94 explorer sport 4x4 im waiting to do a straight trans swap this weekend some in the meantime I've been doing some work to make it look a little better (I cant really take pics while im doing the work as you can see im not in a garage so some days im pressed for daylight) give me some feed back
its stock the day I brought it for $450
thrust glasspack bolted on for now I'm going to get it welded but I want to get new pipes first
changed the colors of my gauges still in the process on finishing the speedo but looks good so far
blacked out tail lights I did the third brake light today
blacked out corner light but need to be touched up and as you see I started to paint the truck I did the front panel just as a trial run I like it but Ima try different paint and suggestions on that?
the inside on the trunk hatch I have to do a second coat of the black as you can see
door panels I really like how these turned out
I think im going to reverse the colors on this since the main color is going to be black
