How to: - Ford A4LD rebuild diary - How to rebuild Ford A4LD | Page 5 | Ford Explorer Forums
How to: Ford A4LD rebuild diary - How to rebuild Ford A4LD
Prefix for threads which are instructional.
Allright...newb question. Can you give a brief explanation of how auto trannies work or if you have a website that it explains it or something.
Originally posted by Glacier991
I am saving this space for a short discussion about snap rings. I am more and more believing that SNAP rings, of all kinds, are somethnig that you should NOT re-use. I have some pix to illustrate this, and I'll add them as soon as I get time.
Considering the relatively low cost of most snap rings vs. the damage that can occur if one fails - I would put reusing them in the "false economy" catagory.
Hey thanks a lot glacier, I really appreciate it. That site is awesome...I've spent all night reading about everything I ever wondered about. Now i just need the experience :)
Final aspect of teardown
Well, as I write this I am already starting into th rebuild, but the onething we didn;t do in this teardwn part of this thread is tear down the pump/bellhousing. No a lot to it. Remove the pump allen head bolts (6mm)
Here's the pump gearset and the pump body once removed
Here's the pump separator plate coming off with the pump removed
And the end of the bellhousing underneath
This was a rebuild... I'll show you in a bit how I know.... but the pump shaft showed ascarsof eccentric rotation (eg lack of beng centered)... I'll post a couple pics hoping to show it... here's the first, see the wear ?
heres the 2nd
And here is the infamous bushing - this one has had some wars... scarred
ok, I had been told this was rebuilt. But I KNEW it was once I had lookd in the bellhousing.
Like rings on a tree, the number of "stake marks" (4 per build) give it away. This seal shows 10 ...equals at least one rebuild.
We will be exchanging the bellhousing for one with a line bored bushing and a new seal.... so with this, the teardown is complete. On the rebuild I will try and show how to DIY parts of the seal and bushing replacement... BUT ....the only right way is to get it line bored.. on this point I AM resolute. Disgree if you like, but GET IT LINE BORED! Or be sorry.
Part 2 continues here:
