- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
The plug and gap should be as you mentioned it. I would prefer to keep the 195 operating temperature. The cooling systems in Fords beyond about 1994 is better, the old school idea of a colder thermostat is not needed(wrong). If you can find a way of monitoring the actual temps, I would do that before any change of temp.
The stock system is very good when operating correctly. My 99 V6 truck never gets over 200 degrees in hot weather while going 30 miles in three hours(lots of idling). I have an electric fan on this truck and it only runs occasionally. Any old Ford would require a constantly running fan in idle, high heat conditions.
I would suggest buying a Failsafe thermostat though, if the coolant gets too hot the thermostat fails open instead of closed. Regards,
