- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
Start relay trigger / circuit goes key tumbler to ignition switch through clutch pedal jumper through neutral safety circuit at dtrs (side of transmission) then to start relay
PCM relay power trigger/ circuit goes from key tumbler through ignition switch through fuse 19 interior through power diode (under hood fuse box) then to trigger to eec/pcm relay
Power for the eec relay goes through battery wires through eec fuse and to relay
Power for start relay is similar except the ground for the relay comes from pats / theft module
