Sounds like a good bit of work.
Here's an easy task, replace the side view mirrors with 95-01 model units. I have them on my 91 and 93 doors. They bolt on the same, only the wiring will need a little arranging at the connectors. You have a Limited, so you can buy the heated version and the wire is already there. If you run a wire to tap into the dome light circuit(black/blue), you can also select the puddle mirrors. Just be sure to only buy Ford mirrors, the aftermarket stuff fits and adjusts poorly. Regards,
