New v3.0 Build Available
peterk9
Staff member
Moderator
Ottawa, Ontario area
2020 Aviator Reserve
Callsign
VE3
Have you checked your Ford owners to see if it shows an update is available? As I've mentioned, I don't recall anyone doing an update over WiFi.
Join the Elite Explorers for $20. Gets rid of the ads!
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
Ferretkingdom
LEHIGH ACRES
2018 Explorer Limited
I haven't yet as I rarely have access to an actual computer. I do most from my phone/tablet and I can't access it that way. I find it interesting though that I'm supposed to be able to update Sync over my wifi, and it says it's up to date, but clearly isn't.
Ferretkingdom
LEHIGH ACRES
Hmmmm.... I had my mom log into my Ford owner amount to look at it for me. It says I have no updates or downloads available, but I'm apparently 2 build versions behind? I don't understand. Is the newer builds only for certain models/years?
peterk9
Staff member
Moderator
Callsign
VE3
As far as being 2 builds behind, that was exactly my thought when you posted your build number. As far as I know, this update is for all those with Sync 3.
Ferretkingdom
LEHIGH ACRES
I am new to all of this. Are the builds vehicle or maybe feature specific? Like, if you have navigation or not or something like that? Where does one find information about these builds of your Ford owner account doesn't show it? Contacting Ford customer support hasn't proven helpful, as they basically just told me what my account does lol
Ferretkingdom
LEHIGH ACRES
Wow. So frustrating. Ford customer support can only read me canned replies and is no acutal help, and my local dealership will charge me $135 plus tax to update me..............WTF. :(
no one in any department of customer service seems to have any clue that there is even a build number for Sync..................
KarmanExplorer
DFW
2019 Explorer Limited
My '18 explorer has build 17276. It tells me it's up to date when I check for updates over wifi. Will it only do the user updates via USB, since I actually want actually up to date even before this newest release
If you go to owner.ford.com web site with your car, does it show an update is available? Mine did for both my cars. I then used the USB method. My wifi did the spinning and spinning till I turned it off.
MM07
MA
Updates are free.
And still nada for me on the portal.
MM07
MA
Just gave my car 15 more minutes of running scanning for updates. Nothing.
I give up for now.
silverkorn
New York
2019 Explorer Sport
It took me a couple days for the Sync Update page to finally load but I was able to get the download link:
https://ivsubinaries.azureedge.net/owner-package/14309196745656227394/JR3T-14G381-AS.zip
Here is the information from the autoinstall.lst
; SYNC3 Consumer Assembly Upgrade - Release 3.0.21 - Only for Nav/NA assemblies.
[SYNCGen3.0_3.0.19205_PRODUCT]
Item1 = HB5T-14G386-THA
Open1 = SyncMyRide\HB5T-14G386-THA.tar.gz
Item2 = HB5T-14G386-TCB
Open2 = SyncMyRide\HB5T-14G386-TCB.tar.gz
Item3 = JR3T-14G391-CE
Open3 = SyncMyRide\JR3T-14G391-CE.tar.gz
Item4 = JR3T-14G381-AS
Open4 = SyncMyRide\JR3T-14G381-AS.tar.gz
Item5 = JR3T-14G423-CB
Open5 = SyncMyRide\JR3T-14G423-CB.tar.gz
Item6 = HB5T-14G387-AAB
Open6 = SyncMyRide\HB5T-14G387-AAB.tar.gz
Item7 = GB5T-14G386-AB
Open7 = SyncMyRide\GB5T-14G386-AB.tar.gz
Options = AutoInstall,Delay
peterk9
Staff member
Moderator
Callsign
VE3
In post #23 he said no update shows on his account.
peterk9
Staff member
Moderator
Callsign
VE3
Updates are free.
Not if a dealer has to do it unless you have specific issue with the software.
peterk9
Staff member
Moderator
Callsign
VE3
I give up for now.
As I mentioned before, I'm not aware of anyone who had it work over the air. Do you have navigation?
Ferretkingdom
LEHIGH ACRES
No, my owner portal didn't show any update available
Ferretkingdom
LEHIGH ACRES
Updates are free.
Not if the car is out of warranty like mine. The dealership is free to charge whatever for their time to do the update
silverkorn
New York
2019 Explorer Sport
Ferretkingdom
LEHIGH ACRES
I got a hold of a service manager at my local dealership and he OK'd them looking at it at no charge. They couldn't find any reason why it wouldn't show I had an update available, so they went ahead and did it at no charge to me, as they said this should fix the bluetooth connectivity issues I've been having since I boughtthe car.
Unfortunately they gave my car back and now only 1 of the 4 tire pressure sensors read on my dash..... this wasn't a problem I had when I dropped it off this morning. Ugh. Stuck at the dealership note abs need to pick up my kid in an hour. :(
peterk9
Staff member
Moderator
Callsign
VE3
Ferretkingdom
LEHIGH ACRES
I was also having trouble with the portal, I had to ultimately open a Sync support chat to explain the issue for which they escalated the case through tech support. Once they fixed it on their end I was able to get the download link to finally populate.
Ford Chat: Contact Us | Ford® Customer Service, Help & Live Chat | Ford.com
Glad you had luck with that. I talked to 7 different people yesterday and spent over 2 hours on the phone and none of the people I talked to even understood the build number thing. They just kept saying i had sync 3.0 and that that was the current version...... when I asked to escalate or speak top a supervisor, 2 of them got rude, told me there was no one else, and disconnected me - one on the phone, one via a chat so I have that in writing.
Similar threads
