Nitrous injector.....
Spdrcer34
Bremerton, WA
1992 Explorer XL
I was reading all these threads about how much of a waste the Throttle body spacer is. If they were designed like this one for the 5.0L engine:
you would see a MUCH bigger gain in performance because the actual runners would be longer, not just the 'log' that leads to the runners themselves....I personally don't believe they have much merit where they are currently placed, but that's just my opinion.
Has anyone ever attempted to install a nitrous fogger into a spacer? It would be super easy to get the mechanicals figured out......getting the jetting right would be a whole other issue....
Anyone here following me?
Take a MotorVator spacer:
Drill & tap a 1/8" NPT hole in the side
Add a Edelbrock or NOS fogger nozzle
And add a Universal Nitrous EFI Wet system.....
Do you think this would make those once useless TB spacers useful now?
Ryan
section525
sextion525
Moderator Emeritus
Red Bluff, Ca
1975 Ford Bronco 4x4
The only bad thing I could think of is a lot of nitrous instructions tell you to install the nozzle 6" from the TB.
Spdrcer34
Bremerton, WA
1992 Explorer XL
But has anyone tried it?
Ryan
Spdrcer34
Bremerton, WA
1992 Explorer XL
Carb'd vehicles have their nitrous plates installed in the 'spacers' directly under the carb. I think it can be made to work with our cars
Ryan
jimbo74
Elite Exploder
Nor*Cal
2001, F150, XLT 4x4
however a carbs way of mixing takes place in a way different spot
Spdrcer34
Bremerton, WA
1992 Explorer XL
I understand that.
But I still feel this will be a very efficient set-up. Set-up as a 'wet' injection you will be suspending fuel in the air, just like a carb or TBI intake. Being so close to the TB, it would create enough turbulence to keep the gasoline suspended.
Ryan
HypIllAuto
Sponsor
Atlanta GA
2004 Adrenalin Sport Trac
I dont see why it wouldnt work. Take some of the mustang kits for example. They have spray bars acrossed the middle of the the TB kits that inject after the tb as well. Then of course, there are the tap in pro kits that actually screw into the manifolds WELL after the TB.
boominXplorer
Elite Ranger
Virginia Beach, Va
00 4x4 Mounty
The reason nitrous is placed after the TB is for less dissapation of shot and a larger shot. A shot where 1 jet can't handle it all or you are trying to hide it. If you put the nossel anywhere past the TB you must do 8 differnt nossels in each port so you get an even shot like you would if you injected right before the TB. Are you trying to hide your nossel or something or are you just bringing up a point?
Spdrcer34
Bremerton, WA
1992 Explorer XL
I would be trying to hide it. And it would only be for a 50-70 shot anyway. I'm not going for MAX power here......just a bit for when I need it.
Ryan
biturbosport
Calgary, Alberta
99' Sport
what do you need nos for anyway?
biturbosport
Calgary, Alberta
99' Sport
that is if you arent wanting to take full advantage of it- why not just run a twin turbo setup or a supercharger?
huskyfan23
Rah no Hans Bwix
WA
1994 XLT 4x4
Price?
Why don't you post pics of your TT sport?
Spdrcer34
Bremerton, WA
1992 Explorer XL
This is just an idea I have running in the back of my mind. I know I could make it work. I know I could make it work for others. That's all. The whole set-up could be had for ~$600USD
Ryan
boominXplorer
Elite Ranger
Virginia Beach, Va
00 4x4 Mounty
Ryan
Aint nothing a little wire loom can't cover up. They way 91-94 intake tubes are set up it should be easy to hide.
BTW Dont leave your bottle in the truck, bad things happen http://www.explorerforum.com/forums/showthread.php?t=124923
Spdrcer34
Bremerton, WA
1992 Explorer XL
The injector would be placed in the TB spacer, inbetween the TB and intake. I think with the stock 'shroud' I have (larger 91-92 version) I could hide almost all of the underhood installation.
Ryan
blk mk8
brother
Troll's
you guys are funny.
