i am also starting to think it may be something in the pcm as well, but i would have to think i wouldn't have any spark, or fuel whatsoever. but, i have been wrong so far! LOL.
yes, lots of things did change from 97 to 01. the biggest was the fuel system (if i am not wrong).
if the part numbers don't match on the pcm's they will not work. i took a chance on the weekend, went to a wreaking yard and pulled a few from some explorers that where there. non of the part # matched, so i didn't even bother plugging them in. i got them for nothing, so at least I'm not out any $
i have the entire truck sitting beside the 01 (parts truck is a 97 sport). i know where your going with this, so yea, i guess it cant hurt anything to try the pcm from it......i think.
welllllllllllllll, here's an interesting update. with the help of a buddy of mine that i mentioned earlier, as well as help from one of the mods on this site, ideas where tossed around from checking to see if the motor was hydro locking from fuel, seeing if injectors where pulsing, bad starter, to compression. i change starters. it cranks a little better, but still will not fire (figuring that the starter was causing too much draw, and possibly robbing the computer of any power to function, hey worth a try right?). then came checking if the injectors where pulsing or not. to do this, i had to remove the upper intake, no biggie. when i did that, another buddy called. he was home, and to come and get his compression tester. i scoot over there, grab it, and come back. i take the plug closest to the rad on the passengers side out, and screw the tester in, and crank the key for 10 seconds. i go to look at the gauge......... it reads nothing. ok, maybe it is draining the gauge down before i can see it. its possible, hell, at this point having lighting strike me in the ass while i am bent over tying my shoes is even possible. so i call up my dad to see if he has 5 mins to come to my house and turn the key while i read the gauge. he comes over, turns the key for me while i am looking at it and guess what?! NO COMPRESSION! zip, zero, nada! thinking ok, there is something wrong with the gauge. pull it out of the motor, and go old school by shoving my finger in the spark plug hole. nnnnoooooootttttthhhhhhiiiiiiinnnnnngggggg!
now how can a motor that was running perfectly fine, go to no compression. i didn't dig into the motor at all. the only thing that i did besides changed the harness, injectors, fuel rail, upper and lower intakes, was turn the motor while i was removing the flywheel nuts. that and, this motor sounds the same as the other one that i replaced when it is trying to turn over! WTF!!!![]()
when i did the compression test, i had knock the cut off switch to the fuel pump so the fuel pump would not come on (and when i turned the key on, i did not hear it cycle, and the fuel reset light was on in the gauge cluster), unplugged the coil pack, and unplugged the injectors. also, before all of that, i had changed the oil, so it had fresh oil.
welllllllllllllll,
. . . i had to remove the upper intake, no biggie. when i did that, another buddy called. he was home, and to come and get his compression tester. i scoot over there, grab it, and come back. i take the plug closest to the rad on the passengers side out, and screw the tester in, and crank the key for 10 seconds. i go to look at the gauge......... it reads nothing. . .
Did you do the compression test with the intake manifold on or off? If on, did you remember to hold the throttle wide open?
How much fuel pressure dose it have excatly???
