NOTAJP goes solid 1st gen. leaves | Page 2 | Ford Explorer Forums
Maybe we could do some measureing and see how much each setup flexes??
I'd like to see some numbers too. Maybe you could measure the height of the bottom of the tire while it is on the forklift. Based on the pictures so far I'm not seeing a coil spring/coil over killer here.
ssoo... using leaf springs for the front will save me how much if i wanna do a SAS? compared with the coil overs. how is the ride quality?
The height of the bottom of the tire while on the forklift was 31". I never meant to build a coil-over killer. This just shows that leafs are a tried and true set up, and will flex just fine.
Looks great! I love 1st gens for offroad and the front and rear glass fenders look awesome!
Are you going to get it painted? Is so What Color?
Needs clear corners front and rear!
No matter how you slice is, unless you are getting coilovers for free, a leaf spring swap will be cheaper.
However, a traditional coil, when setup properly will be very close to the cost and has the potential to outflex a leaf spring setup. It will also excell in other aspects.
Flex isn't the only factor to consider when swapping suspensions.
You should also consider:
1) Approach and departure angles
2) Pinion angle change during flex
3) Axle wrap
4) Stability characteristics
5) Frame limitations
A leaf spring setup will not allow for best approach and departure angles.
A leaf spring setup is more difficult to get proper pinion angle change.
A leaf spring setup will wrap up.
In terms of stability, that depends on where you mount the springs (leaf or coil). Without a sway-bar (Anti-Rock) the leaf will probably provide for better stability, but at the cost of flex.
You will encounter frame limitations with any setup.
The bottom line is that you should go with what you want, what you understand, and what you can afford.
I disagree that coilovers are overrated. I think the phrase should be re-worded to say that coilovers are over-glamorized. People think they need them when in reality a traditional coil and shock setup would work perfectly.
Swap came out good. :D Any close up pics of the brackets that aren't so blurry?
I forgot to ask, are you going to run a trac bar?
Originally posted by NOTAJP
I really don't want to step on any toes but my pictures prove that I have just as much, it not more flex then Taxxman and JoshC.
Why compare your truck to Josh C's or Taxxman's? Why don't you compare your truck to another first gen that has the same advantages as you in the frame? Mine is limited by too short shocks in the rear, and stock bronco radius arms, but I still get 35" to the bottom of the tire on a ramp. Michael's flexes even better than that, and both trucks have coils.?
Oh, and why downgrade to a Dana 30?
Thanks Cory, as always I appreciate your insight even if we disagree sometimes. I do plan to run a sway bar for highway speeds as I drive this thing all over the place at 80+mph. "over-glamorized" is a good word and I'll work with that. For now my shocks will be the limiting factor until I can afford 14" travel shocks.
Josh,
I don't plan on running a track bar for now unless I have serious issues later on down the road. It feels good now, just have to get it on the freeway.
Black Magic,
Thanks man. That means a lot comming from a beautiful X yourself. Hopefully if work and time is on my side, I'll be shooting the paint this winter. It'll be Kawasaki green. If everything else is wild, the paint might as well match, right? Oh yeah, my wife is bugging me to get the clears done as well. I'm going to upgrade the tail lights to the 98+ style because the fiberglass is designed for it. Hind sight says I should have just done the '98 conversion for the front....:rolleyes:
I couldn't tell you an exact $ until I got a chance to write it all out. I see you will be almost starting from scratch. It all depends on what you want. It will all depend on if a shop is doing the work or you will be.
CoryL could give you a better idea of cost factors. I'm sure he'll tell you that a coil setup will be cheaper from him. The steering can be a huge $$$ factor based on what axle you use. Coil overs are $500 each. That does not include and of the engineering involved with the three or four link suspension that it'll require.
Jefe is about to build a coil-over SAS on a 2nd gen, check out his URL=http://www.explorerforum.com/forums/showthread.php?s=&threadid=73370]thread.[/URL]
I like the ride so far. I haven't really played with it off road or more than 30mph yet. I'll keep you updated on the ride and drive this weekend when we get to play with it.;)
SOB!!!:mad:
Man you can't do yours green. Thats what I had planned for my X.
Originally posted by Derrick C.
SOB!!!:mad:
That's bad...and in the same state. I guess I'd better get mine done first.:D I've already started painting so you're just gonna have to go dark green!;)
Yeah you'll get yours done first. I still have to cut out the rear windows and roof. Then the fiberglass. Then paint.
Maybe I'll go back to Racing Blue. Damn it man.....now I have to think about it.
Make him go Sunflower YELLOW
On another note if I had access to a 77 Early Bronco wouldn't the SAS set-up be easy if I got the complete axle and all steering components??
Oh and FYI my son wants me to paint mine Yellow with silver racing stripes down the hood
i like the idea of yellow but make it a darker shade of yellow it ya do so it will not fade
There ya go Derrick, sunflower yellow is all yours! :D
That swap would almost be bolt on (except for the trac bar). It is that easy with the EB.
Yellow would be cool. I like that Yellow on the Nissan Xterra. That's what I thought about using on my FJ40 project. I don't think there's another sport around that's Yellow, or any other X except for Perry.
You would still have to deal with the radius arm/radius arm mount choice. You would probably have to swap to EB (or really any SFA -'79 Ford) radius arms with the c-bushing ends and they will be longer (I am pretty sure) than your stock arms. Even if they were the same length, you would probably be looking at some type of dropped arm bracket, depending on spring choice. Then you have to deal with drag bars and trac bars.
NOTAJP, the swap looks great!
The high-steer is a nice choice and a great addition!!
Thanks Robb!
I meant that the entire suspension from the EB would have to be swapped. Sorry for the confusion. The only fabbing would be the mounts for the EB radius arms and the track bar mount on the frame. The EB coil buckets fit perfectly on the first gens. The stock EB radius arms are the same length as the extended 1st gen arms. If I were to do an EB SAS, I'd run a complete James Duff stage II suspension.
Congrats NOTAJP:thumbsup: Good job. I wish I had half of your fab skills. I kow you'll get many hours of enjoyment out of your rig.
When I started my swap last year my first choice was to go with leaf springs due to the cost-simplicity of the design, minumum of breaking parts and low maintanence. I still think it's a good option.
I decided on the 4 link, coilover design after analyzing some of the points CoryL mentioned. In the end what you decide on depends on 2 factors. Preference-usage, and cost.
Have fun:D
Thanks Tom. It deffinitely will not keep up with your Navajo (neither will my wallet), but it'll do the job. I don't have anything on the quality and skills that went into your front end. That is truely amazing. This will be fun and it works for me.
Now that I have the SAS off my mind for a bit, I can get back to working with the fiberglass. I played with the Marine-Tex the other night and I think it'll be perfect for the fenders. I'll keep you posted.
Here's a couple pics with the shocks painted and mounted. Derrick, this is my color. ;)
Here's another shot of the M.O.R.E. steering plus the modification.
I wouldn't do the zinc coating again. I want to send the steering rods to Boise for some chrome plating.:D
