ArcKamikaze
- September 15, 2010
- NY
- 1999 XLT V6 SOHC Explorer
Hi, just joined forum, have a question about my 1999 explorer (V6 SOHC) involving the O/D light blinking, I've looked all over the forums to see if I could find a solution but couldnt find one. Basically my situation is that my truck drives fine, starts up good, aside from the rattle (guessing timing chain, not loud and goes away after driving), everythings fine, feel a kick/jump when reaching 30 mph, at the same time the rpm's kick up then go back down, dunno if thats a problem or if its normal (first ford), problem occurs whenever I frequently brake at stops and drive off, after a while the O/D light would randomly come on and switch the truck to safe mode (or limp mode), have no problems shifting or braking, just accelerating, seems to lag. The problem goes away if I turn the truck off then on, then the o/d light wont come on again till ive left it off for a long while or the next day. This problem occurs randomly, and while driving, never on startup or in park, not sure if the problem is simple to fix or if its serious, any help is appreciated.
PS: Tried pulling the codes at auto zone, but nothing, was told that in order for them to pull codes they needed the truck off, except when I turned it off the o/d light went away and no codes pulled up, was thinking about buying a scanner, but after autozone im not sure, is there a scanner that can pull codes with truck left on?
