mechjames
- September 27, 2007
- Richmond, BC
- 1994 Explorer XLT
I have an opportunity to get a friend's SOHC engine from a 98 Explorer that was crashed. It was rammed into the passengers side, and after hitting the inertia switch, the motor started up great and didn't seem to have any timing chain rattle at all. It has 240,000km. Mine has 298,000km and I found a chunk of something in the oil pan, so I have to pull my motor to find out what it is, and I also need to change the rear main seal.
Until this opportunity showed up. I've seen some threads of some people who have attempted this swap. What I have found out is,
-The SOHC will run on the OHV computer if you spend a lot of time splicing the SOHC wiring connectors into the OHV harness
-By doing this, you can keep the A4LD with the 3-4 shift and overdrive.
-You have to modify the heater box to make room for the SOHC valve covers
-Air conditioning can be retained if you take the lines out of the SOHC truck.
-Since it is a early SOHC, the intake manifold is a return system, so it will work with my fuel line setup from the OHV.
But would the EEC-IV give me the mileage and power of the SOHC with an A4LD transmission? Instead of OBD-II with the later model transmission?
Am I correct in the above?
Now since I would pretty much have unlimited access to this truck for wiring, why don't I:
-Pull the whole harness and computer and convert to OBD-II
-This would mean I would have to use the SOHC transmission because the OBD-II can't shift the A4LD 3-4 and O/D, and would probably throw codes for 1, 2, and 3 because the solenoids wouldn't be there
-Would the new transmission hook up to my transfer case alright?
-And if I did a bit of wiring I could make the OBD-II work with my stock first gen dash (like tach)
-And with 2nd gen having air bags, and 1st gen doesn't, would this cause any issues?
The deciding factor will be what is found in my oil pan (I had the oil tested @ Blackstone and Aluminum spiked during that OCI). It only has 50,000km less then my motor now. How reliable are the SOHC's in their high mileage years? Maybe there would be more SOHC's at the wrecker in the future if I do this swap later.
I have 2 weeks to decide. Chime in with your thoughts.
