Slowlyvverot
- August 27, 2009
- Greensboro, NC
- 93 ExElTee
derp
Well after 210,000 miles my LS is pretty much toast. I don't even think it worked at 180k when I started driving my Ex. And I don't have the option to swap in a locker in the rear unless I want to spend $$$ on one that replaces the carrier. With an open diff you can just buy a cheap lunchbox locker and throw it in there.I'm looking at replacing my axles with junkyard 4.10s after I get my tax return. I was torn on whether to get LS or open. So the factory LS isn't worth it?
To get the 4.10 I have to go to 2nd gen so I get the disc brakes anyway, which everyone seems to say is worth it.
As far as everyone else, the only other strong consensus is a winch is one of the best mods for your buck?
My biggest recommendation would be to skip drop brackets when lifting the front end, and go with cut and turned beams. My 91 explorer had drop brackets when i got it and they cracked from all the stress, and i know plenty of other people who have had the same problems.
If I could start over with another RBV with what I know now (not much lol), my mods would be 31s, 2" springs front and rear and lockers front and rear.
Everyone keeps mentioning COG, which is part of the reason I wanted to keep it to 4" lifted, but will tires affect COG much?
I have 31x10.5 now and for my next set I've been torn between 32x12.5, 33x10.5, or 33x12.5. It seems like 33x12.5 will rub from what I read. So is it worth losing the extra inch of height to gain the extra 2 (4 total) inches of stance if I go with 32x12.5?
Well I'm screwed there now...not only did I do drop brackets but they're Rough Country. I full well knew of their "hardcoreness" issues before I bought them but single dad = not a ton of extra cash. They're on there now so here goes nothing....
to keep your COG low, fender trimming is a must.
Im rockin 33x12.5s on a 2" lift front and rear with about as much fender metal removed as possible without actually removing the fenders. only the rear tires rub at full flex. slightly longer bump stops would fix that and still keep most of the travel back there.
You got a good welder? (all's not lost if so...) Some reinforcement (widening) on those brackets (and modifying the RC drop-plate extension so the diff doesn't smack it) should keep you going through some relatively heavy use (basically what I did with mine). You might have to do something about the coils though, RC coils are pretty stiff and won't offer much flex.
Not a lot I would have done differently. My main regret was that when I did my SAS I put a Detroit Locker in the rear axle, unaware at the time of their reputation for destroying themselves if you break an axleshaft. I would have spent more money and bought an ARB.
Before my SAS, I regretted not putting the Lock Right in the 8.8" sooner! I might have done a Powertrax No-Slip instead, though because it was still a DD and the No-Slip, while still a lunchbox locker, supposedly has better street manners.
I would go a little higher then 4:10s if you are going to run 33's.
Ok, I did some math...
If I run 4.56 with 33s I'm roughly at 2,384 RPM in overdrive.
If I run 4.10 with 32s I'm roughly at 2,216 RPM in overdrive.
Is there really that much of a difference? I mean, on the low end? I would think those ratios are pretty dang close, and for the money I can get into 4.10 a lot cheaper. Don't get me wrong, I think I would absolutely be happy with 4.56 but I'd like to get new axles in this summer. I could handle the price of 4.10s a lot easier.
Thoughts? Are guys running 4.10s really that disappointed with the performance?
Idk, sell me on one over the other, somebody.
If I get a winch and 4.10s with a rear locker am I really going to be that unhappy vs 4.56 open and no winch? Cause realistically that's about what I'm looking at dollar vs. dollar on those options.
I know I will never go bigger than 33s ever, btw, strictly because at that point it seems like virtually everything gets upgraded. There's not enough regular wheeling in my future to necessitate anything larger than 33".
Did you mean to change the gear ratio AND tire size in your calculations?
If you mean both to be 33" tires the 4.10's drop the ratio by more than 200 rpms, which gets you to "about" 2150 rpms @ 65mph.
We run 4.10's and at 60mph its < 2000 rpms which means when we even "see" a hill, it doesn't have enough oomph. I really wish we had the 4.56 for our 33's.
Since our X is no longer a DD, or if it is used as one I don't go over 65 (normally its 62 mph) I'm looking at really upping the ratio to 4.88 or possibly higher (since we might go 35's later).
~Mark
