Carguy3J
- June 21, 2008
- North East New Jersey
- '99 4dr. XLT SOHC A4WD
OK, I have a '93 Ranger 4x4, 4.0L/5spd
The pitman arm is bad. The tapered hole for the center link ball joint is worn out, so there is WAY too much slop in that connection.
Sounds like an easy enough fix, right? Wrong...
Every parts source I can find lists Moog K8754 (or a simlar "house" brand part) as the replacement. It's the wrong part. This part# is straight. It appears to be for a 2wd Ranger. The old, stock part on my truck has a bit of a drop to it. No, my truck is not lifted.
I've tried looking it up for a B4000, but then they have nothing listed at all.
I have found Moog part# K80787, listed for a 4x4 '91-'94 Explorer. This part looks more like what's on my truck. The Explorer seems to use all the same part#'s as the Ranger, for all the other steering linkage parts (as I would expect.) My question is, does anybody KNOW (not think, suppose, or guess), that the '91-'94 Explorer 4x4 pitman arm should be the same as my '93 4x4 Ranger? I can't imagine any reason why it would be different, but who knows? Maybe the Explorer mounted the steering box at a different height relative to the linkage?
Please help. I need to do something asap. I need the truck to make money, and right now it's not safe to drive.
Thanks
Thanks
