ssp.interceptor
- February 5, 2010
I can't say for sure how much more you can squeeze out of them with a custom cam. I would definitely run it by FTI and see what they say. Ask them about how much power you could squeeze out by going from 64cc camber to a 58cc while your at it. In any case you'd be losing 50lbs. off the front end with the aluminum vs cast irons. I just haven't seen impressive results on mustangs with them vs iron gt40's, but none that I can remember had a custom cam or tune either.
Have you thought about a 347 kit? You could get one for what your going to pay for the heads and rebuild kit. I'd think a 347+P Heads+Custom Cam would make more overall torque and power across the range than a 302+GT40x+Custom Cam combo, and would be about the same price either way. Would be better suited for a 4,500lbs truck and I'm willing to bet that a custom cammed 347 with gt40p's tuned will make better power than a 347 with gt40x's heads and an X cam.
BTW, I'm not in anyway trying to tell you what or how to do your build, just trying to help you figure out what you want and what would be the best power per dollar package.
Looks like you are getting there-Is Geoff helping you? Dang, did I even spell his name right?
Quick update motor is finally out. It's on the stand with the pan still on it. I'm gonna go out and drain it here in a bit then start cleaning the engine bay, the block&Pan and lower suspension. THere's oily grease and dirty everywhere. I had an oil leak from both main seals apparantly. Oh and Jon, I seen there's a little bit of rust on the collecter flange of the headers. Is there any paint that can be used to withstand the heat from the headers. I was thinking of painting them black now since I seen that.
Ok, On Monday I'm going to try to get all the parts bought to rebuild the lower end of the motor since I still don't have my heads back yet and still haven't heard back from flowtech about my custom cam. Oh yeah, were ya able to get Eric's Harmonic balancer off yet?Try some aluminum foil, dip it in coca cola and scrub the rusty spot--
Other than another ceramic coat, nothing will hold up
