jordanka16
- June 24, 2010
- Corvallis, OR
- '96 Explorer Sport
I have a '96 Explorer Sport that has had the radio wiring mangled by the previous owner, I have managed to get the radio working again, but the power antenna is stuck in it's closed position.
The wires that provide it power from the radio have been cut, and I have tried to manually extend it but it doesn't budge. I had the idea to put power to the motor temporarily to extend it but can't figure out which wires do that. I can see two wires coming from the motor, one is green with a yellow stripe and the other is red, powering either does nothing. At this point I just want the antenna extended, I don't care if it goes up and down, I just want more than one radio station.
First picture is the motor with the two wires coming from it, second is where the wires end, they are to the left and wound around the antenna wire. There is also a plug in the bottom of the picture with two wires the same color as the antenna wires.
Thanks for any help.
