Preventative Transmission Maintenance - 07 Sport Trac | Ford Explorer - Ford Ranger Forums - Serious Explorations
dogbus
FL
07 Sport Trac V6
I previously owned a 2008 Ford Explorer XLT which unceremoniously blew it's transmission on the way to the supermarket. I had a long battle with it, trying to diagnose a seemingly haunted PCM, as well as any service on the transmission being a complete pain in the ass. I purchased a 2007 Sport Trac with 70k miles on it and want to know what kind of work I could be doing to keep the transmission in good condition or replace it altogether with a newer build 5R55W (or different transmission?).
What are my options for preventative transmission maintenance?
Failing that, which newer build 5R55W's are worth the investment?
Is it possible to put a different, higher quality transmission in it?
Fix4Dirt
Get a Load O' This Guy!
Los Angeles, CA
1998 XLT 4x4
shift kit and sonnax upgrades are good for those trans. aside jusr fluid and filter. only thing better would be to drop a v8 in with a 6r80. are you sure yoi have the 5r? since i thoight the later sport tracs had the 3v and 6r60/80 like the non tracs
dogbus
FL
07 Sport Trac V6
most research ive done says its a 5r but i wouldnt know any better. how would i change fluid and filter if its a "leakless" transmission and i cant change the fluid without going into a shop? would shift kit/sonnax upgrades be good as preventative? just his about 82k miles on it
Fix4Dirt
Los Angeles, CA
1998 XLT 4x4
the later ones were sealed trans. they can still be changed however! yes i think for the 5r they are good prevebtatives to prevent flares etc
