Project Green Hornet '01 Sport SAS | Page 5 | Ford Explorer Forums
I also got around to fixing the lean. I have to add a pro comp leaf and remove the bottom leaf of the pack and it got it pretty close. Once it settles it should be perfect. I did a little cutting on the front fenders to make them line up with the bumper a little nicer. I still need to figure out something to prtect that edge from tires and other stuff. I'm thinking about some kind of hard plastic trim like a UHMW, but not sure yet.
I cut my driveshaft in prep to get it extended this week. When I did it caught fire which I though was weird and sure enough there was a cardboard sleeve inside. Is this normal? I definately was not expecting it either way.
I've never heard of cardboard in the shaft before maybe it was how someone extended the shaft in the past. It would work as it looks hold the tubes in alignment until tacks and full welds can be achieved.
And I've been watching your thread for some time. I was hoping that since you already had the tape marks in the past that sometime you will build a set of these.
Cardboard is put in driveshafts as a sound deadenor, been done for as long as I can remember.
T
Those are on my list, but quite a ways down. I still have sliders, back bumper, tranny/transfer case swap yada yada yada. I'll get around to it maybe next summer when it's hot out.
Yea, that's what a buddy of mine said too. I just wasn't expecting it I guess.
I hope everyone had a good thanksgiving.
Here are a few poser shots from today. I am figuring out shock location and bump stops. I should be able to get this wrapped up soon and get some real flex shots.
Looking Great !
absolutely amazing. I'm hoping to have the skills and knowledge to SAS my sport someday. maybe when i move to Virginia next year, i'll be able to meet someone who would be will to hold my hand and walk me through it. lol
However like you, i'm waiting for my x to take sh*t on me before i do anything major. But with as much as i baby it, i dont see that happening anytime soon. not sure, if thats a good thing or a bad thing.
I did about 4 years worth of reading and searching through threads on this forum before I tackled this thing. I am by no means an expert, but getting your hands dirty is the best way to figure things out. Having a non-mobile truck makes things better because you can go at your own pace and screw up and not put yourself in a bind. As far as babying your ride, I did the same so just wait your turn it will take a dump ;) they all do at some point.
You're going to want to put rim stiffeners on your parts list/to do list. I have the 8 bolts on my truck and lost a wheel to a tree stump. bent the outer ring just enough to let all the air out.
Not a picture of the damage to the wheel... but a picture of what the damage caused...
Yea, that sucks bad. They are definitly on my parts list when I recenter and get off these spacers too. For now, I will see more trail riding and take it kind of easy until I go full 4x4 (new trans/transfer). I am kind of digging these rock rings from trailworthfab.com on something like this wheel center:
Add my voice to the chorus ... this is just amazing work. Great research, great pics, great explanations. Just great stuff. Looking forward to some trail pics down the line.
:exp:
i may have missed it, but did you build the front bumper or buy it? also what holds the grille in? I have an 01 sport that im just getting started on, hope to be wheeling it by summer of 2013 (fingers crossed)
ah ok thanks..im really anxious for mine to be DONE, sadly im going to have to contract out a lot of the suspension (fun) work. I simply do not have time to build the thing and Im ready to be wheeling with the ac on!
A/C? You don't need A/C, just roll your windows down. :biggthump
Hell, I totally removed my A/C components except for the A/C heater box ( gotta get a A/C delete ranger heater box for that) and it'll open up alot more room in my engine bay.
Well, I'm finally done.... sorta'... I mounted all of the shocks and finish welded everything and added some bump stops in the rear. The front didn't look like it would need them so I haven't done them. If I get into trouble later I'll go back and add them. I took it out on a test run around the neighborhood and had TERRIBLE death wobble, so I ordered a ram and hoses/fittings from surpluscenter.com. I ordered the 1.5x8x1.0 ram to help stabilize and also help with steering all together. The steering wasn't bad, but that wobble really didn't feel good. I'll get that put on in the next few weeks and hopefully get it back on the road. I also noticed that it was having a hard time going up and down hills and I thought I smelled some burning. I hope it's not the trans having a hard time shifting because of the VSS. I will look into that a little closer next time I take it out. Here are some pictures of the work I did. These are the upper rear shock mounts that I cut from f250 shock towers.
Here are the shocks mounted:
