mbrando1994
- May 17, 2015
2003 Ford Ex XLT
4.0 V6
Hi everyone! I am the proud owner of a 2003 Explorer xlt. I've been having a rattle issue lately in the front end when going over a certain type of bump. It seems it occurs after hitting the bump and the tires fall back to make contact with the ground. (In other words it usually only rattles when it's a raised bump vs a pothole).
I took it to the garage and they said it was broken sway bar end links..made sense.. so they fixed that, along with a bad front wheel bearing and rear brakes. After wards the rattle was gone! Though there was some vibration in the steering wheel when going approx. 75 mph on the interstate. I also noticed some shaking in the steering wheel when hitting certain bumps. Then as you could imagine the shaking eventually stopped but the rattling returned! It originated on the front passenger side tire, but now seems to be on both sides in the front. It's that kind of noise that injects fear into you of your car falling apart you know? I just need some advice on what this could be and how to fix it! I have jacks/stands and all the necessary tools.
Thanks in advance!
Brandon
Thanks in advance!
Brandon
