I'm all good for the 23rd. Gonna see if I can get that limited slip put in.
make sure you swap the ring gear, and check the backlash as thats your main drive axle and tolerances must be on, also be sure to torque ALL internal bolts (ring and bearing cap bolts) to spec.... if you want help and can get up here, I'll give you a hand droppin it in as I have all the necessary tools.
albi1cnobi1 said:I'm lurking... possible.
albi1cnobi1 said:You think my little stocker will make it back in 1 piece?
just got back from wheeling... medium difficulty... somewhee. Had a good time, the crawl box works awsome! nuttin like 6.2:1, although the linkage needs some work... time to veg!
