Accarguy
- September 25, 2014
- Chicago, IL
- 2000 Explorer 5.0 AWD
So my beloved 5.0 that i spent half the summer rebuilding is going through oil. I had the engine out because the rear main and front cover was leaking. So the engine got broke down into a million pieces and most of everything got replaced trying to do things the right way and I put in a comp cam while I was at it.
But now after having around 7,000 on it now since the rebuild and I noticing that I am going trough about a quart of oil every thousand miles. I broke it in on 5w30 synthetic and is still on synthetic. I have changed the oil at about 500, and about 3000 miles since. I see nothing dripping or even wet underneath and no blue smoke out the tailpipe, I am thinking but hoping not the piston rings are the issue. I really do not want to pull the engine out again.
I also do have a slight lifter tick still after putting on adjustable roller rockers but I think that is the not so good lifters that came in the kit with the cam. But I think that is the least of my worries right now.
If anyone has any insight or has been through this before could chime in, thanks for the help.
