M.D. Farragher
- January 17, 2019
- Location
- Western Washington
- Mukilteo, WA
- 1995 Explorer XLT
I recently rebuilt the brakes on my 1995 Ex XLT. New pads in the rear, new extended flex lines, calipers, rotors, and pads in the front, and one new ABS sensor on passenger side. Also replaced the rigid passenger side line in the front as I discovered the fitting was stripped. Bled the crap out of them and have a nice firm pedal. Not everything got replaced at the same time. First the pads all around, then the front flex lines, then the ABS sensor. When I took the vehicle out for a test run the ABS howled and it pulled to the left. I figured I hadn't bled them enough so I did it again. Same hard pedal. Same result. Replaced the calipers and rotors because I was going to do it anyway with 175K on them, and now was as good a time as any. Bled it again, got same firm pedal, and same, ABS howl, and pull to the left. In the meantime I had replaced the rigid line on the passenger side, and wound up with the same result. Pulled the two 30AMP fuses in the relay panel for the ABS, and howl goes away, and vehicle brakes dead true. I should add that there are no ABS lights on dash when the fuses are in place and it is performing badly.
Any ideas or input? ABS module? ABS pump? Can either be tested?
