How to: - Recover your Center Console (10 Steps) | Ford Explorer Forums
How to: Recover your Center Console (10 Steps)
section525
sextion525
Moderator Emeritus
Red Bluff, Ca
1975 Ford Bronco 4x4
If your center console is ripped, falling apart, etc. it is really quite easy and inexpensive to just recover it yourself.
Step One:
Remove the three screws at the bottom of the lid.
Step Two:
Find a nice area to work on.
Step Three:
Flip the lid over and remove all the screws and remove the black pastic lid.
Step Four:
Remove all the staples currently holding the vinyl on.
Step Five:
Remove the vinyl from the armrest.
Step Six:
Spread old vinyl over your new vinyl and trace.
Step Seven:
Cut relief cuts near the front edges.
Step Eight:
Start on one side and staple the edge down. Then stretch over to the opposite side and staple again. Keep stretching to the opposite side inorder to get a nice tight cover going on. :cool:
Step Nine:
Place black plastic back on and gently screw the screws back down.
Step Ten:
Screw it back onto the console and you're done. :cool:
Now if you really try you can probably find a gray/tan etc that is pretty right on with your interior color. I wasn't too worried about it. Also, I think I spent about $12 on vinyl for about 5 lids or so. So it's very very cheap.
very nice write up..... Mine before was brownish grey from all the dirt and i just scrubbed and scrubbed and it came out very well.
I have done multiple interiors like this, a good thing to have is a can of spray adhesive. It helps a lot. You can also use this process to add inserts on your door panels.
-Rich
what about 1st gens? How do we recover ours? mine is in BAD shape
hey sextion525 when I saw this write up over the summer I knew I was going to be doing it, well I got home from college and it was one of the 1st things I did. your directions were perfect :thumbsup: nice job!
now for proof ;)
Dan
Now if you really try you can probably find a gray/tan etc that is pretty right on with your interior color. I wasn't too worried about it. Also, I think I spent about $12 on vinyl for about 5 lids or so. So it's very very cheap.[/QUOTE]
Where are you guys finding the correct color vinyl for your ex's mines dark graphite grey.... any ideas?
Take the lid off and bring it with you. I found a 10x10 scrap of tan vinyl at the fabric shop for $3.00 and its dead on color wise.
here my transformation...... they didn't have the right color in vinyl (too light)
so i ended up getting this plether but the color is actually closer then the picture shows :) (when people see it now they dont even notice till i tell them :D :thumbsup: )
old
New
Cheap and easy just the way I like it...
-Rich
What all did you actually cover?
Nice write-up btw! :thumbsup:
Good write up. I have been wanting to do this for a while.
Where did you all get your replacement vinyl from?
Got mine from a surplus shop. I dug and unrolled every color that was close. B4 we left my son actually said look at this one its perfect. I was ready to leave and just blow it off but took a look anyway. Needless to say I got all they had, its perfect match even the texture matches the seats.
i need to get some pics of mine, i think its actually time to redo it, i had some wear in the foam, but i just covered it, the little indent didnt bother me.... haha, i didnt know about relief cuts, i jsut pulled it tight, you cant tell it isnt factory, except there is one spot on the front corner where there is a slight fabric overlap. i couldnt find the exact color although they probably had it, so i jsut went with black, it looks really good considering the rest of the console to the dash is black too
oh yeah, make sure you use short staples, i used a electric power stapler and it was great, but it had long staples in it, they came through the foam and vynil on the otehr side, good thing i had more vynil, and shorter staples that i then used
wow awesome write up cant wait to do mine!
Great job on the article. I see so many of them worn, it's such a simple procedure if people would take the time to do it.
Great write up
I did this repair before I joined the forum. I think that it is a DIY project, but be patient and buy extra material. You will need it after you make the first mistake. LOL!
I was at the junkyard, and got my material from the back of a seat. I cut off the pocket, and bam, enough to recover this. my biggest problem was that the damn staples wouldnt go into the plastic! sooo frustrating
center console lid
I bought a reupholstery kit for my center console lid and heres the results:
found for around $20 on ebay.
heres a link to the guy who sells em: http://motors.shop.ebay.com/merchant/impact954
just letting anyone know that if I can install this, then anyone can.
