natenkiki2004
Blue Bomb!
- November 3, 2013
- Location
- North Idaho
- 1991 & 1994 Explorers
Has anyone done this? I'm talking about the air temp sensor sitting near the vacuum tree on the upper intake plenum. On newer Explorers, the upper intake is plastic and it seems on many other newer vehicles, the IAT is located at/in/near the MAF. Even Ford went and put the IAT in the MAF sensor (6-wire MAF).
I'm just curious if anyone has done this mod, either on an Explorer or other vehicle. I couldn't find anything in the way of a intake spacer to help keep the plenum cooler. So I'm wondering if maybe the computer got the temp of the air from the plastic tube or air filter box, if maybe the temp reading would be more accurate. The upper intake plenum is a large and sealed chamber with thick aluminum. It might heat the air up quite a bit especially with short stops.
There shouldn't be any huge difference while driving though, the air should travel through fast enough.
I don't know... let's have a discussion about it
