Welcome to the Forum.
Hopefully someone will have the answer. I've never used the fob to lock/unlock the doors. Just tried it and with mine (2017) it just activates the lights. No horn. I can't recall if my 2011 was the same.
Thank you for the warm welcome, Peter.
I was able to find a solution for activating feedback for remote unlock/lock (with a FOB) for the 2013 PI Sedan.
It's located in
this post by PlatinumOwner
Simply change BCM 726-15-01 to: xxxx 0101 xx. (the first 1 is horn feedback, the second 1 is light feedback),
"xxxx" values are to be ignored / do not change them.
The aforementioned change can be applied via either the
easy method in FORScan, or advanced mode (accessing individual addresses and values inside each module). Both methods have their advantages and disadvantages.
I had to reprogram the 5-key FOB for the feedback to work. Reprogramming instructions
here.
Useful references:
FORScan Intro and Decoding Spreadsheets(with links to various spreadsheets of FORScan codes for different Ford models)
Unlocking Features on the 2013+ Ford Police Interceptor Guide
Tools Used / Purchased:
-Windows 10 PC Laptop w/ built in bluetooth
-Modified ELM327 Bluetooth OBD2 w/ HS-CAN/MS-CAN Switch & Microchip //
$24.93
-Keyless Entry Remote Start Car Key Fob Control (5 button) //
$28.45
-FORScan version 2.3.10 beta for Windows -
free
(Making these changes will require the extended licensing for Forscan, which is only available in the Windows version. You can get a 2 month free trial by first
registering , THEN completing
this form)
