removing coolant tubes 5.0 | Ford Explorer Forums
nonhog
Pacific N/W
2000 Explorer sorta
The coolant tubes on the RH side of the engine, how the heck? LOL
I searched but maybe phrased it wrong. I am thinking about taking it off and redoing it to fit better in my Volvo. (engine swap)
Puts the hoses too close to the firewall.
Anyway I looked in my FSM and found nothing.
Tips? And do not disturb is a valid tip! :)
This picture might help. Beware the smaller lines halfway up the tubes ( not seen in this picture) circulate coolant through the upper plennum--
yes, the threaded part spins. I think I have a cut wrench for this, to allow a pipe for a wrench extension. You will need to eat your wheaties for this, it's on there good. Note the red lock tight sealer stuff.
I think I might get by w/o removing it after all. But nice to know if I need to.
It seems that the pipes might be spot or tack welded together as I cut the tab between the two and they stayed together? Anyway like I said I may be o.k. w/o pulling it. Good info for the next guy!
Hello everyone, I have an issue with those tubes; I have a leak in the rear part. I'm trying to remove it, but I still can't. What type of wrench do I need to unscrew the part where the sensor goes? Does anyone know how to bypass the tube? Is it really necessary to have it? I would really appreciate any info given! videos and pictures are welcome too!
