reschool me on my d-44's
project92
missouri
00E.B.,93 xlt 92 xlt
been away from the d-44's for a while... my question is I got a chevy 44(87 model) and a set of rotors off a ford 44 (3/4 ton 78 model) I'm wanting to make the chevy 44 a 8 lug front for a project does any body know if I can just put the ford rotors on the chevy axle?... I know I can do this chevy 1/2 to to chevy 3/4 ton but I couldn't remeber if DANA changed much from the nuckles out on their front ends....
DB_1
Elite Ranger
La Quinta, Ca.
97 SC Ranger xlt
Don't know much on the rotor swapping since i've never done it myself but here's a good webpage that might help you out:
http://77cj.littlekeylime.com/web_rs44.html
Is the Chevy D44 going on your Ex? The diff will be on the wrong side unless you have plans for a different T-case.
project92
missouri
let's just say a wild project... and yes it would be on the wrong side if I was using the ford t-case.... seeing by his one bearing chart a 79 chevy ford is the same so I went to autozone web page and it seems the 87 uses the same bearing...
IZwack
Moderator Emeritus
Germantown, MD
1998 Ford Explorer
Im 90% sure you can.
I did something similar by switching an FSJ 6-lug axle to 8-lug using a hubs/rotors from a 1985 K20.
IZwack
Moderator Emeritus
Germantown, MD
1998 Ford Explorer
Oh and the brakes is another thing you need to look at -- on the FSJ axle for example, a set of Chevy backing plates and calipers were needed.
Overall, I think it might be easier for you to stay with the Chevy line for this 8lug swap -- the '85 K20 is a good base as parts for it are widely available. The K20's calipers is also a lot easier to deal with than the Ford's because the Ford is a stupid rubber wedge thing where as the K20's is a sliding bolt caliper design common in modern vehicles.
project92
missouri
acutally why I asked is I have a extra "free set" of ford eight lug rotors and free 373 posi 3/4 rear but a 373 1/2 ton front end...so my whole ideal was take the rotor and slap them on the chevy axle... thanks for all the info... just waiting on the guy to buy my motor out of the sport so I can get started.... easier to sell a motor they can hear run...
james t
Moderator Emeritus
Texarkana AR/TX
94 SAS sport
I dont know if it was a typo, but if your front is out of an 87 then its a 10 bolt. :)
sn0border88
Master Apprentice
Souderton, PA
1992 XLT
If it was a typo and you have a 77-79 1/2 or 3/4 ton then yes it should work with the matching year ford rotor. If it is an 87 your SOL.
Also if you want highsteer nows the time to swap knuckles (unless you lucked out and already have them)
