Scott B's 93 Ranger XLT V8 | Page 4 | Ford Explorer Forums
Rebuilt the Rear Axle
After 140,000 miles, the pinion seal started leaking. Instead of just changing it, I decided to freshen up the entire axle.
Bearings and seals all around. After pulling it apart, I found that I need an axle repair bearing on the right side. I guess next time, it will time to replace the axles - LOL.
Here's a picture of the empty housing. Note: this is much easier when the axle is not under the truck!
Finally got around to installing these, from Colorado last fall.
And, I need to replace the tailgate latch handle. Just for the record, cutting through the Rhino Lining on the access panel was a pain.
That seal is a pita! lol
The stickers look good Scott. I slapped mine on the drivers side rear glass, and they still look good all these months later :)
Just seeing them stickers makes me reminisce of being there.
The new pinion seal leaked, too. I changed it yesterday - I think it is sealing now...
That was a good trip to Colorado last year - I'm ready to go again, right now!
BTW, are you thinking about going to Uwharrie in July this year?
Wish I could afford 2 meets in the same month, but can't. :(
Smorr is in July also.
I even had to give up my trip to Moab this year. :(
Hopefully the economy will be turned around, and work will be plentiful, so I can make the trips I want to go to.
I just picked up a new spare tire. My previous one was a Dunlop 265-75-15 - and it was 15 years old! It was about the same height as my BFG 32s, but slightly narrower. I hated to toss a tire with less than 1000 miles on it, but being 15 years old, I was concerned about rot.
As you can see, my next set of tires will be a new tread pattern!
FedEx dropped a box off today! These are new JBA headers that I had coated at Jet Hot.
They sure are purdy!
Nice, there's a very good chance my next tires will be KM2s and i have outlaw wheels also, so i was wondering how they'd look. I'll probably get the white letters mounted out also, they look awesome!
...Now how the heck I'm I ever going to catch up to you with all this bling you are throwing on your Ranger??...:p:
Excuse me - it's not "bling" - it is essential equipment required for safe, efficient travel in the backcountry.
Just cause it looks purdy is irrelevant!!!!!!
Tbars - just wait for 4.3 under the hood!
...Well....Well....You just wait and see...:p:
...What did you add to the first post and how did your exhaust end up sounding?,,,Did you wind up with a nice deep sound?
...What did you add to the first post...
Quick disconnect front swaybar
...how did your exhaust end up sounding?,,,Did you wind up with a nice deep sound?
It sounds good at idle outside the truck, and drones a bit inside while driving. No headers, no cam - I guess it's to be expected. Yours sounds better.
This exhaust is due to be replaced - the muffler is rusting from the inside.
I should probably replace the cats (they have lots of miles on them!) and remove the exhaust pipe restriction just after the cats. I want a true 2 1/2" system with a single-side outlet.
I think I'm going with either JBA or Magnaflow - both are stainless steel systems, so they shouldn't rust.
...I thought you already installed those purdy JBA headers...:(
You are thinking of the '06...
Interesting Problem
I pulled off the left front hub today, as a previous inspection had revealed a light silver color in the wheel bearing grease - the typical color of ground metal in the grease. I thought I had a bad wheel bearing.
To my surprise, I found this: a worn, mangled thrust washer! I have never seen this before. Apparently, it jammed (lodged?) on the stub axle, and rubbed on the spindle. I had to use a Dremel to cut it off the stub axle.
The good news is none of the bearings were contaminated. While everything is apart, I will clean and re-grease everything, change all the seals, install new thrust washers (from Ford, I guess.)
...Were you missing the C-Clip?
...I've only seen that when missing a C-Clip or when the outer spindle nut came loose...
